rlsimpso Posted May 23, 2006 Share Posted May 23, 2006 Has anyone ever looked in to putting a SVX 3.3 or OB H6 3.0 in place of an EJ25? SVX engines are pretty cheap on ebay. I would guess it would need an adapter to go a 5 speed. I seem smallcarperformance does a 5 speed conversion for the SVX, but not seeing anything about an adapter. I seem to remember a rally racer who put a 3.0 in an impreza. Am I correct is assuming transmissions mounts are the same between the 4 and the 6? If so, it should be a direct swap, right? I am sure the computer and harness are completely different, so that would all need to go. Upgrade the rad and probably do front suspension too, as the 6 should be heavier. Anyone who has done a n/a to turbo engine swap think this would be more or less difficult/problematic then that. My goal is get a more power and hopefully more reliability over the EJ25. I am not looking to make a crazy street racer. I would go buy an STi and call it a day, and have a warranty:) Would I be better off looking at a jdm turbo ej20? I am nervous about buying a used turbo engine. Thoughts? Rob Link to comment Share on other sites More sharing options...
SuBrat84 Posted May 23, 2006 Share Posted May 23, 2006 I think it would be a pain in the arse to try and cram that motor into that engine bay. Probably some cutting required. Link to comment Share on other sites More sharing options...
rlsimpso Posted May 23, 2006 Author Share Posted May 23, 2006 Supposedly the 6 cylinder engine is only a 2-3 inches longer then the 4. I was looking at an 04 OB H6 at the dealer the other day and it is tight, but it fits in the same space as the SOHC EJ25. They managed the cram one in a VW Vanagon too:) . Rob Link to comment Share on other sites More sharing options...
benebob Posted May 24, 2006 Share Posted May 24, 2006 SuBrat84 said: I think it would be a pain in the arse to try and cram that motor into that engine bay. Probably some cutting required. Actually, the 3.3 will fit in an Impreza engine bay without any cutting or the like. Problem is you need to relocate the cooling system and air condensor just so you'd be able to change accessory belts. Link to comment Share on other sites More sharing options...
NoahDL88 Posted May 24, 2006 Share Posted May 24, 2006 the 3.0 is shorter than the 3.3, has more power, and has been built longer so parts are easier to find, and its more reliable. if it were me i'd go 3.0, and its got a timing chain so no probs with the t-belt. Link to comment Share on other sites More sharing options...
SuBrat84 Posted May 24, 2006 Share Posted May 24, 2006 NoahDL88 said: has more power REALLY? Hmm.. My friend who drove my stock SVX w/ 200k+ miles said it pulled harder than the Tribeca he rented. (I got to ride in it.. ) Maybe it's a weight thing.. Anyway, back on topic... sounds like it would be a bit better to go with the 3.0 in this case.. for parts and probably tuning as well.. and definately for fitting it in there. It takes me 1/2 hour just to change the plugs in my svx Link to comment Share on other sites More sharing options...
nkx Posted May 24, 2006 Share Posted May 24, 2006 the folks at perrin crammed a turboed 3.0 H6 into a 2006 sti... Link to comment Share on other sites More sharing options...
benebob Posted May 24, 2006 Share Posted May 24, 2006 NoahDL88 said: the 3.0 is shorter than the 3.3, has more power, and has been built longer so parts are easier to find, and its more reliable. if it were me i'd go 3.0, and its got a timing chain so no probs with the t-belt. Yes the 3.0 is shorter but it doesn't have more power. Hp is higher. 250 vs 230 but Torque is weaker at 212 vs 230 for the SVX. By far the SVX engine is a better engine and making everything else equal it just as reliable if not more so than the 3.0. It is just not likely you'll find a 3 year old 20k SVX motor but you can find a 3 year old 20k 3.0. Not sure about the 3.0 logevity elsewhere but it isn't any older than the 3.3 yet here in the states as the SVX was made for 5 years and this is what the 4th for the 3.0? As for the chains vs belts. Personally I'd take the quieter belt over a chain which will only get ya about 1.5 times the life as a belt. Link to comment Share on other sites More sharing options...
rlsimpso Posted May 24, 2006 Author Share Posted May 24, 2006 Do you have link to the perrin sti? Link to comment Share on other sites More sharing options...
BruceyWV Posted May 24, 2006 Share Posted May 24, 2006 Here is a write up I figured you might be interested in: http://linaracing.com/impreza-h6-conversion-faq.cfm Cobb also is thinking of producing superchargers for the H6. http://www.cobbtuning.com/cobbtuned/ct_tribeca.html I cant find the turbo H6 in an impreza link though, I think it was made by perrin. Link to comment Share on other sites More sharing options...
nkx Posted May 25, 2006 Share Posted May 25, 2006 http://www.jtuned.com/content/templates/2005-centralhall.aspx?articleid=353&zoneid=18 http://www.supercars.net/cars/3278.html Link to comment Share on other sites More sharing options...
SakoTGrimes Posted May 25, 2006 Share Posted May 25, 2006 Why hasn't anyone suggested the EJ22 yet? I'm not suggesting that, just asking why no one has yet. Link to comment Share on other sites More sharing options...
offroadsubaruguy Posted May 26, 2006 Share Posted May 26, 2006 more power = :brow: less power = :mad: i would take a 3.0 or a 3.3 over the 2.2 any day..... Link to comment Share on other sites More sharing options...
Tbird Man Posted May 26, 2006 Share Posted May 26, 2006 the 3.0R is a better design and is going to have more aftermarket support. the EG33 is really just an ej22(NA) with two cylenders slapped on, whereas the EZ30R was designed from the get go as a 6cyl. Link to comment Share on other sites More sharing options...
benebob Posted May 26, 2006 Share Posted May 26, 2006 Tbird Man said: the 3.0R is a better design and is going to have more aftermarket support. the EG33 is really just an ej22(NA) with two cylenders slapped on, whereas the EZ30R was designed from the get go as a 6cyl. Yeah, your right. There's a lot of ej22s out there with 4 cams aren't there. I think you're thinking of the 27 which wasn't much more than a EA82 with 2 extra cylinders. The SVX however, has virtually nothing in common with the 22. Link to comment Share on other sites More sharing options...
WoodsWagon Posted May 26, 2006 Share Posted May 26, 2006 Every engine mentioned, 2.2, 2.5, 3.0, 3.3 has the same bellhousing pattern. They all will bolt to a 5spd legacy or impreza tranny. No adapter needed. I belive that 3.3 pistons are interchangable with 2.2's. This would tend to support 2.2 with 2 extra cyl's slapped on. Which is not a bad thing. The 2.2 was the most rock solid engine ever built by subie (power wise, EA81 peeps keep you shirts on) So building off of that would be good right? The 2.5 was an all new design, and it blew lots of headgaskets. Link to comment Share on other sites More sharing options...
benebob Posted May 26, 2006 Share Posted May 26, 2006 91Loyale said: Every engine mentioned, 2.2, 2.5, 3.0, 3.3 has the same bellhousing pattern. They all will bolt to a 5spd legacy or impreza tranny. No adapter needed. I belive that 3.3 pistons are interchangable with 2.2's. This would tend to support 2.2 with 2 extra cyl's slapped on. Which is not a bad thing. The 2.2 was the most rock solid engine ever built by subie (power wise, EA81 peeps keep you shirts on) So building off of that would be good right? The 2.5 was an all new design, and it blew lots of headgaskets. Not the same pistons. Wish they were b/c I could get some decently stronger ones made cheaply. As one who owns two SVXs and races one of them, I'm fairly familiar with the engine and what can be used and what can't. It was pretty much of a show piece engine of its day and shares virtually nothing (not even a oil filter according to Subaru) with the 2.2. Link to comment Share on other sites More sharing options...
SvRex Posted June 17, 2006 Share Posted June 17, 2006 You'll need 4" more for the SVX motor than a 4 cyl, assuming you leave the radiator in the same place. It will bolt directly to a 5 speed (I've got a 5 spd SVX). Link to comment Share on other sites More sharing options...
