skishop69 Posted May 25, 2006 Share Posted May 25, 2006 I'm going to be dropping th ER27 into a Brat and lifting it. Has anyone used thwe electric ps pump on other applications or can it be done? I'd really like ps with the bigger tires and I don't see any way to mount up a mech pump without serious fab work. Quote Link to comment Share on other sites More sharing options...
mikeshoup Posted May 25, 2006 Share Posted May 25, 2006 Gary mounted the XT6's electric power steering pump in his 4 cyl XT (that normally use belt driven pumps). You probably just need a power steering rack, some power steering hoses, and plug 'em into that electric pump. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted May 25, 2006 Share Posted May 25, 2006 i removed the belt driven pump on my XT Turbo. now the XT Turbo is an EA82 model, so is your GL/DL an EA82? if so, the XT6 rack will swap right in without any issues at all. you'll need the rack and the hard lines that attach to the rack. if you do that, it's a straight swap, no custom work at all. then get the pump and lines as well. not sure the layout of the DL/GL though, might be some minor things in the way, spare tire or something. but that's no big deal. i do not have it powered yet though, haven't decided on powering it full time or trying to get the stock power controller/computer set up to run the pump. but i know jeep guys that run these pumps as well and they run them constantly powered with no issues. Quote Link to comment Share on other sites More sharing options...
