Announcements
Wrx Brat
rguyver
  rguyver said:
CORRECT !!! i got a 2004 USDM complete STI in parts so the motor tranny and rear diff will be swapped in but it may not happen till this winter if i still want to drive it this summer , it will require new custom axels , wiring ,diff mount and shifter boot , and i havent figured out if i will need to make the tranny tunnel bigger " i think yes " so cutting and welding in the bigger tunnel is going to have to happen .
damn! that would be sick!!
I've heard that the 6MT is the same size as an EJ 4EAT. which Gloyale proved only barely fits in an EA82 tranny tunnel......yea, I think you'll have to do some modifiying to get it all to fit.
also....r180 in a brat :slobber::slobber:
I'm officially more jealous of your brat than I was before. I didn't know that was possible! Nice freakin work man!!!!!!
  • Replies 57
  • Created
  • Last Reply
Top Posters In This Topic
  MatthewakaMatt said:
I've been lurking on the forum for a bit, and was rather interested in this thread. I too have been contemplating swapping the engine and drivetrain from a STi into an old hatch or brat as a M4 rallycross car. I would guess that the end result could be quite a lot lighter and faster than a STi or even a swapped Impreza coupe.
Do you know what your brat weighs now?
its just over 2200 lb but i think it will push over 2500 lb with the sti engine and tranny , its not so much the car that is heavy its all the 4x4 drive train but thats around 900lb lighter then a loaded STI .
I am no longer concerned about the weight its faster then the tires can hold :burnout:
What are you going to do with the old axles? I'd be interested in buying them from you. I'm going to convert my Hatch to AWD and 5 lug wheels next summer (as you already know) so I could really use those axles. Let me know, I'm in no big hurry.
Thanks, earl
  rguyver said:
this is an up date on my brat as it is now, i added the STI seats powder coated intake and role bar
guess what this is and what it may go in to ???????
OMG...:slobber::slobber::grin::slobber::slobber:
yes 4eat is the same overall size as a six speed I'm betting that with xt6 and six speed crossmember parts one could bolt a six speed into an 87+ ea82...but damn.. into a brat? Holy fabrication batman! Gonna be totally amazing. I can't wait:burnout::burnout:
Kaz
Thanks, earl
i havent decided what the WRX engine and tranny are going in too yet but ill keep you in mind if i want to sell them .
i may sell it as a complete package for a swap in to a older EA .
  Quote
What does it cost to make those axles? I would love to make my brat AWD! Even with 4lug!
the machine work and weld would be around 200$ an axle + core depending on the work needed or 200$ + the cost of 2 axles if you wanted to keep the 4 lug because you would need a EJ inner and EA outer ends put together .
So basically you need RX axles...
Or any turbo axle from after 1980, right?
Twitch
Twitch
if you are going to keep the 4 lug yes 1985 and newer turbo axles would work too for a AWD EJ trans swap or change out the shafts in the tranny for the smaller ones from a non turbo EA tranny to be able to just use the stock shafts , but you will have to split the case to swap the shafts .
no Ea81 had 25 splines
Ea82 and EJ22 axles are longer and will not work with EA81 control arms.
so, if you want a 25 spline trans and EA81 hubs.....there's probably a way to put 25-spline DOJ cups on the EA81 shafts.
i thought so too but i havent found that conversion shorter shaft for the front that has the same shaft splines as a EA82 or newer so i just cut them so i can get the bigger joints at each end .
I had a set made by CV of Ocala a long time ago and they were fine. I ended up splitting my trans case and making the 23 splines stubs fit the trans which was easy. Made the prospect of a road trip without bringing a spare custom axle along a much nicer car to take.
  Jibs said:
When getting custom axles made, how much of a factor is in balancing the shafts? Would it wear the seals and things a lot faster if the axle shaft was unbalanced?
if the shaft is built and spun on a lathe it would not need to be balanced as long as its not bent .
What kind of custom work did you have to do , to get the wrx trans mounted in.Was there any cross members that would work for the trans?
or was it all fab work? I would like to see pics if possible. I'm doing a complete wrx swap into a 85 gl 10 wagon. Thanks Robert in Portland
custom cross member , i welded the old 4speed and the EJ 5speed along with some square tubing so i could use the EJ STI tranny mount .
i dont have any pics now but ill try to get some up some time .
best thing to do is have the tranny in the car and held up with a jack and start trying to fit, cut and weld something to hold it up , dont forget exhaust pipe clearance.
