Announcements
Wrx Brat
rguyver
  • Replies 57
  • Created
  • Last Reply
Top Posters In This Topic
I would love to see pics of the steering rack installation and what you did to shim it in there.
i dont have any pics of building it but some time later ill try to get pics of it installed .
  • 4 weeks later...
Ive got a fuel question. I am putting a n/a 2.2 in an 86 brat and am wondering about fuel lines and fuel pump. Should I use a pump from a turbo brat or put an aftermarket inline fuel pump in? Also, do I need to to upgrade fuel lines? Thanks.
fuel lines will be ok for a N/A 2.2, i have used the turbo pump but any good fuel injection pump will work as long as it holds a constant 40+ psi , if you are going to go over 200HP you will need to upgrade the fuel lines and return line , i used the stock supply line as the return and put in a new 3/8 main supply.
  • 1 year later...
  • 3 years later...
  • 11 months later...
