Syonyk Posted May 29, 2006 Share Posted May 29, 2006 '87 GL, SPFI. I've removed the bolt that keeps it from twisting, I've pulled the rotor off, and... I can't get it out of the engine. It was stuck pretty solidly, so I used a strap wrench to turn it (and broke one of the little spring clip things... are those easy to find?), and it'll turn to the ends of it's adjustment area, but I still can't get it out of the engine. I need to pull it so I can replace it so I can get the car running again. Suggestions? Other than "Pull the engine, take it apart, hit it from underneath"? -=Russ=- Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 29, 2006 Share Posted May 29, 2006 You pulled BOTH of the adjustment bolts right? The EA82 has two mounting tabs. Get a good shop light or flashlight and take a look down there. You'll see it. Both are (should) be 10mm. GD Link to comment Share on other sites More sharing options...
Syonyk Posted May 29, 2006 Author Share Posted May 29, 2006 GeneralDisorder said: You pulled BOTH of the adjustment bolts right? The EA82 has two mounting tabs. Get a good shop light or flashlight and take a look down there. You'll see it. Both are (should) be 10mm. GD Two? *goes to look* ... *comes back with the distributor* Yea. Thanks. That did it. -=Russ=- Link to comment Share on other sites More sharing options...
Syonyk Posted May 29, 2006 Author Share Posted May 29, 2006 Now, compatability questions: I don't know my EA82s as well as I know my RX-7s, so... This is what I have: 22100AA053 D4P84-03 6802 This is what someone is offering me: 22100AA440 D4P86-03 B 1404 Are the compatible enough to work? -=Russ=- Link to comment Share on other sites More sharing options...
hooziewhatsit Posted May 29, 2006 Share Posted May 29, 2006 if they're both out of an SPFI engine, they *should* work. You may have to swap the connectors on them as well. Just unscrew the cover from the disty (two screws on the bottom), then pop the harness out to switch them. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 29, 2006 Share Posted May 29, 2006 As long as it came from another fuel injected EA82 it will work. SPFI, MPFI, even turbo all use the same crank angle sensor distributor. It's really a very simple device inside. Nothing like the carb units. Timing is really controlled by the ECU. You might have to change the plug on the end depending on what year it came from, but it *will* work little effort. GD Link to comment Share on other sites More sharing options...
mikeshoup Posted May 29, 2006 Share Posted May 29, 2006 I thought some had a vacuum advance unit, and some did not. I'm pretty sure the diaphragm thingy on my Turbo's dizzy with a vacuum line to it is a vac advance... seems to me 87+ don't have a vacuum advance, and instead are controlled by the computer? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 29, 2006 Share Posted May 29, 2006 mikeshoup said: I thought some had a vacuum advance unit, and some did not. I'm pretty sure the diaphragm thingy on my Turbo's dizzy with a vacuum line to it is a vac advance... seems to me 87+ don't have a vacuum advance, and instead are controlled by the computer? That's true, but the crank angle sensor should be the same. Should still work. GD Link to comment Share on other sites More sharing options...
