Caboobaroo Posted May 29, 2006 Share Posted May 29, 2006 I searched for a couple hours last night to hopefully come across a page that had pics of EA82 lifter teardown, cleaning and installation. Does anyone have a link to that by chance? Link to comment Share on other sites More sharing options...
Caboobaroo Posted May 29, 2006 Author Share Posted May 29, 2006 *bump*..... Link to comment Share on other sites More sharing options...
Caboobaroo Posted May 30, 2006 Author Share Posted May 30, 2006 This is the link that I found for the lifter teardown, cleaning and reassembly BUT I get a 404 error everytime I try to open it... I think the page has been moved... http://homepage.powerup.com.au/~camn...lifter_fix.htm Link to comment Share on other sites More sharing options...
manxsta Posted May 30, 2006 Share Posted May 30, 2006 Yep..it has been moved..i dont get the error..but it does tell me it has been moved...the lifters are simple and you dont really need the tear down guide...but i know it gives added moral support should you lose track of which bit goes where...really though,... pull one apart and after the first one you will be a master lifter reassembler:grin: ...serious..the only bit you must be gently with is the retainer,on top..dont damage it up to bad so you cant use it again...polish all the bits with thinners and a rag..or simular and reassemble and your done....cheers....if you find any that you can push down more the .5mm with you thumb..change it for another lifter... when you clean them..it does not matter that they push right in as they will pump up....happy servicing.. Link to comment Share on other sites More sharing options...
