October 28, 200322 yr One of my head lights finally went out on my 98 Outback. I intend to replce them with the Sylvania Silver Star lights. These are supposed to be very good. Any comments. Website
October 28, 200322 yr Luki: I put a pair of Sylvania Xtravisions (not the same as what you're talking about, but maybe similar) in my '97. There were noticeably better than the OEM lights, but only lasted me for about 10 months before both burned out almost at the same time. The dimmer OEM ones are now back in. YMMV. Steve
October 29, 200322 yr Author Well, I bit the bullet and installed them. I was very careful not to let the bulb touch anything. We will see how long they last. They are much brighter and whiter. Those OEM lights sucked.
October 29, 200322 yr I put Silver Star's in about 6 months ago and am very pleased. Much whiter and brighter.
October 29, 200322 yr Yes you have to be VERY careful installing halogen bulbs. Do not touch the actual bulb with your hands at all. If you do, get some rubbing alcohol and get it off. The oil your skin secretes will cause the bulb to burn hotter than it's supposed to and will cause the bulb to burn out prematurely.. Trust me I know :brolleye:
October 29, 200322 yr Author Yeah, I was super paranoid when I installed them. The bulbs did not touch anything organic or otherwise. That is the only that I saw that was bad about my outback. I put one light in and turned them on so I could compare. The new bulb was at least twice as bright and much whiter. The "uber" outback is ready to roll!
October 29, 200322 yr To clarify, I guess I should have mentioned that I didn't touch the bulbs either and was very careful in installing them... and they still burned out in less than a year. I would suggest carrying spares in case they both go while you're on the road, I know I would based on my experience. I had to drive home with my foglights. But, like I said, YMMV; I hope they last longer for everyone else Steve
October 29, 200322 yr Author Good point. I did keep the one working headlight and stored it in one of the compartments in the back. Next up is to figure out how to replace the front signals. But that is another post... Till then.
