Announcements
Woohoo PARTS ARE HERE!
WOOHOO I'm excited, all my parts for the motor just came in!!!
Check it out :
BRAND NEW TURBO GEN3 HEADS FROM SOA :)
ALL BRAND NEW Heavy Duty VALVE SPRINGS
Delta's 272grind CAMS and SHIMS :)
O-Ringed Head Gaskets
ALL BRAND NEW OEM Head Bolts
ALL OEM Gaskets
I'm pulling the motor out tonight, I will keep everyone posted!
I'm determined to have the fastest GL-10 :)
Getting it ready for race season and dyno day.
Stay Tuned!
  • Replies 57
  • Created
  • Last Reply
Top Posters In This Topic
yes, also wanna know...
The springs came from a local guy I found through a friend, he said he got them from Paeco a long time ago and never got around to building his project.
He sold em to me for $100, which is a good deal since there are 16 springs on the ea82-t's and OEM's go for around $150.
I'm tearing the motor out right now as I type so I will post some more pics tonight before I goto bed.
More to come!
I allready have all supporting mods on the car.
Here's what I got :
Engine Internals ALL NEW and Freshly Rebuilt
Engine Internals Blueprinted and Balanced
Greddy E-Manage Ultimate Engine Managment w/MAP Sensor (deleted MAF)
Nissan 280ZX Turbo 450cc Injectors
AEM Adjustable Fuel Pressure Regulator
2-row Heavy Duty Radiator w/Dual Electric Fan Conversion
MSD Blaster 2 Ignition Coil
2.25inch Stainless Exhaust
It should be fine :)
More PICS :
Dude that thing is gonna be SICK! We'll see it at the WCSS right?
-Brian
For SURE, it was at WCSS7, people might remember it, AIR RIDE suspension set on HI 4-wheelin' :)
Never got stuck once, it was a beast!
damn that thing is going to be badass :slobber:
I really want to see some pics of the O-ringed headgaskets!
and maybe a write up on how to install the fuel system? think lots of people are interested... at least I am :-p
More Progress tonight :
Well everything is going smooth so far, assembled both heads, lapped in the valves, put the heads on the motor and torqued them all down.
I'm waiting on the cams from delta, there in the mail and should be here any day.
Tomarrow im fitting the TD04 on with the new flange and welding it all together, basically I measured everything out today and test fit the turbo on the motor, and I'm going to have to raise the turbo UP about 3/4inch, to clear the dogdone bracket, I also had to relocate the EGR Soleniod. So what I'm going to do is CUT off the studs on the stock turbo flange, then grind it all down smooth, then I'm going to CUT off the outter stud part of the flange, about 1 inch of it needs to be removed, then the new TD04 Flange can sit directly on top of the ground down stock flange which will bring the turbo UP 3/4inch and cutting that part of the stock flange allows the outter bolt hole on the new TD04 Flange to fit.
Intercooler piping should be easy, looks as I need (1) 90degree Elbow (2.25inch Turbo Inlet to Intake) , (1) 90degree elbow (2.50inch Throttle Body to IC) and some streight pieces to fill in the gaps.
Coolant Feed and Return Fittings on the TD04 are angled differenly, this is OK but puts lots of extra stress on the hoses because of the ODD bends, so I swapped the Coolant Pipes from the STOCK turbo to the TD04 and everything is perfect now.
Well im beat for tonight, enjoy the pics, More to come tomarrow!
nice! Have you figured out how you're planning on plumbing it yet? I got some pics if you wanna take a look
Im still trying to figure all of that out, good news tho is I have access to a pipe bender that does 2-3" :)
If you could send me your pics I would really appreciate it.
