Steveman09 Posted May 30, 2006 Share Posted May 30, 2006 WOOHOO I'm excited, all my parts for the motor just came in!!! Check it out : BRAND NEW TURBO GEN3 HEADS FROM SOA ALL BRAND NEW Heavy Duty VALVE SPRINGS Delta's 272grind CAMS and SHIMS O-Ringed Head Gaskets ALL BRAND NEW OEM Head Bolts ALL OEM Gaskets I'm pulling the motor out tonight, I will keep everyone posted! I'm determined to have the fastest GL-10 Getting it ready for race season and dyno day. Stay Tuned! Link to comment Share on other sites More sharing options...
Steveman09 Posted May 30, 2006 Author Share Posted May 30, 2006 Added PICS, Enjoy Link to comment Share on other sites More sharing options...
carfreak85 Posted May 30, 2006 Share Posted May 30, 2006 :slobber: WOW! Thats going to be a sweet engine! Any plans for head work? Link to comment Share on other sites More sharing options...
Caboobaroo Posted May 30, 2006 Share Posted May 30, 2006 PICS OF O-RINGED HEADGASKETS! Link to comment Share on other sites More sharing options...
operose Posted May 30, 2006 Share Posted May 30, 2006 PICS OF O-RINGED HEADGASKETS! yes, please Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted May 31, 2006 Share Posted May 31, 2006 Where did you get the heavy duty valve springs?Are you running the OEM subaru valves also? Link to comment Share on other sites More sharing options...
Caboobaroo Posted May 31, 2006 Share Posted May 31, 2006 Where did you get the heavy duty valve springs?Are you running the OEM subaru valves also? yes, also wanna know... Link to comment Share on other sites More sharing options...
Steveman09 Posted May 31, 2006 Author Share Posted May 31, 2006 yes, also wanna know... The springs came from a local guy I found through a friend, he said he got them from Paeco a long time ago and never got around to building his project. He sold em to me for $100, which is a good deal since there are 16 springs on the ea82-t's and OEM's go for around $150. I'm tearing the motor out right now as I type so I will post some more pics tonight before I goto bed. More to come! Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted May 31, 2006 Share Posted May 31, 2006 God those are beautiful... its sure gonna suck when that engine blows up. Hope you got a box with some fuel management parts comming soon. Keep us updated. -Brian Link to comment Share on other sites More sharing options...
Steveman09 Posted May 31, 2006 Author Share Posted May 31, 2006 I allready have all supporting mods on the car. Here's what I got : Engine Internals ALL NEW and Freshly Rebuilt Engine Internals Blueprinted and Balanced Greddy E-Manage Ultimate Engine Managment w/MAP Sensor (deleted MAF) Nissan 280ZX Turbo 450cc Injectors AEM Adjustable Fuel Pressure Regulator 2-row Heavy Duty Radiator w/Dual Electric Fan Conversion MSD Blaster 2 Ignition Coil 2.25inch Stainless Exhaust It should be fine More PICS : Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted May 31, 2006 Share Posted May 31, 2006 Dude that thing is gonna be SICK! We'll see it at the WCSS right? -Brian Link to comment Share on other sites More sharing options...
Steveman09 Posted May 31, 2006 Author Share Posted May 31, 2006 Dude that thing is gonna be SICK! We'll see it at the WCSS right? -Brian For SURE, it was at WCSS7, people might remember it, AIR RIDE suspension set on HI 4-wheelin' Never got stuck once, it was a beast! Link to comment Share on other sites More sharing options...
Turbone Posted May 31, 2006 Share Posted May 31, 2006 Did you win the state lottery? Cant wait to see it run @ WCSS8:burnout: Link to comment Share on other sites More sharing options...
joostvdw Posted May 31, 2006 Share Posted May 31, 2006 damn that thing is going to be badass I really want to see some pics of the O-ringed headgaskets! and maybe a write up on how to install the fuel system? think lots of people are interested... at least I am :-p Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted May 31, 2006 Share Posted May 31, 2006 I also want to see the o-ringed head gaskets.Also any chance you have any connections on where to get higher strength/heavy duty valve springs for ea81?I am looking for some. BTW- The car looks like it is a sweet project. Link to comment Share on other sites More sharing options...
Steveman09 Posted June 1, 2006 Author Share Posted June 1, 2006 More Progress tonight : Well everything is going smooth so far, assembled both heads, lapped in the valves, put the heads on the motor and torqued them all down. I'm waiting on the cams from delta, there in the mail and should be here any day. Tomarrow im fitting the TD04 on with the new flange and welding it all together, basically I measured everything out today and test fit the turbo on the motor, and I'm going to have to raise the turbo UP about 3/4inch, to clear the dogdone bracket, I also had to relocate the EGR Soleniod. So what I'm going to do is CUT off the studs on the stock turbo flange, then grind it all down smooth, then I'm going to CUT off the outter stud part of the flange, about 1 inch of it needs to be removed, then the new TD04 Flange can sit directly on top of the ground down stock flange which will bring the turbo UP 3/4inch and cutting that part of the stock flange allows the outter bolt hole on the new TD04 Flange to fit. Intercooler piping should be easy, looks as I need (1) 90degree Elbow (2.25inch Turbo Inlet to Intake) , (1) 90degree elbow (2.50inch Throttle Body to IC) and some streight pieces to fill in the gaps. Coolant Feed and Return Fittings on the TD04 are angled differenly, this is OK but puts lots of extra stress on the hoses because of the ODD bends, so I swapped the Coolant Pipes from the STOCK turbo to the TD04 and everything is perfect now. Well im beat for tonight, enjoy the pics, More to come tomarrow! Link to comment Share on other sites More sharing options...
Steveman09 Posted June 1, 2006 Author Share Posted June 1, 2006 Update: I got the mods to the stock header done today and it all worked out perfectly! The new TD04 Flange is welded on and ready to go!!!! Enjoy the pics, more to come! Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted June 1, 2006 Share Posted June 1, 2006 Congratulations! Great Job is that... Nice images too... I`ll love to see more Pics of that, so I`ll be Waitin` Also I wanna see Racing that Beast! Very Impresive. Definetively NICE!!! Link to comment Share on other sites More sharing options...
Caboobaroo Posted June 2, 2006 Share Posted June 2, 2006 so where did you get those cool headgaskets from? Link to comment Share on other sites More sharing options...
mikeshoup Posted June 2, 2006 Share Posted June 2, 2006 so where did you get those cool headgaskets from? Hm. Those are the same that came with my XT. I wonder what brand those are? Link to comment Share on other sites More sharing options...
Steveman09 Posted June 2, 2006 Author Share Posted June 2, 2006 The headgaskets are made by Ishino (Japanese) I got them online from : http://replacement.autopartswarehouse.com/parts/autopartswarehouse/wizard.jsp?year=1987&make=SU&model=LOY-4WDT-001&part=Cylinder%20Head%20Gasket&dp=false Link to comment Share on other sites More sharing options...
Steveman09 Posted June 2, 2006 Author Share Posted June 2, 2006 TD04 TURBO HAS FINALLY FOUND ITS NEW HOME ON MY EA82 Link to comment Share on other sites More sharing options...
Caboobaroo Posted June 2, 2006 Share Posted June 2, 2006 nice! Have you figured out how you're planning on plumbing it yet? I got some pics if you wanna take a look Link to comment Share on other sites More sharing options...
Steveman09 Posted June 2, 2006 Author Share Posted June 2, 2006 nice! Have you figured out how you're planning on plumbing it yet? I got some pics if you wanna take a look Im still trying to figure all of that out, good news tho is I have access to a pipe bender that does 2-3" If you could send me your pics I would really appreciate it. Link to comment Share on other sites More sharing options...
torxxx Posted June 2, 2006 Share Posted June 2, 2006 I got a set of those for 35 bucks a piece in town I'll check at work tommorow and see what brand I got. Prolly the same as the pic posted. Mine look just like that Link to comment Share on other sites More sharing options...
