1slow_si Posted May 31, 2006 Share Posted May 31, 2006 While cranking, I sprayed starting fluid down throttle body and nothing. So, I assume no spark. Where do I start? Any common problems? Thanks, Bill Quote Link to comment Share on other sites More sharing options...
SuBrat84 Posted May 31, 2006 Share Posted May 31, 2006 You can check for spark by pulling the wire off of the coil and seeing if the coil is making a spark if you hold a plastic or rubber handled screw driver near it. If you have a multimeter you should turn your key to on.. hold the common on your ground wire or negative terminal and test each side of the fusable links with dc voltage should be about 12.5V.... check all of your fuses under the dash too.. Quote Link to comment Share on other sites More sharing options...
