Caboobaroo Posted May 31, 2006 Share Posted May 31, 2006 Well for those of you who have torn into an EA82, you know those o-rings that go in between the cam case and and heads? One per side, located toward the top IIRC. I'm looking at replacing those while the engine is apart and was wondering if these are them? http://oem.thepartsbin.com/parts/thepartsbin/wizard.jsp?year=1989&make=SU&model=LOY-4WDT-001&category=All&part=Cam%20Housing%20O-Ring&dp=false Thanks! Link to comment Share on other sites More sharing options...
jacobs Posted May 31, 2006 Share Posted May 31, 2006 I just purchased six camshaft o-rings for my EA-82 from Rocket seals (an o-ring supplier in Denver) and paid about 60 cents each for them. If you get down to Denver in the near future, you might want to look them up or they may sent them to you. I just took one of my old ones in and they matched it up. BTW because they are metric, most auto supply houses don't have them. Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted May 31, 2006 Share Posted May 31, 2006 Hey Russ,if they are in denver just let me know if you want me to go check them out and I will send em to ya. Link to comment Share on other sites More sharing options...
manxsta Posted May 31, 2006 Share Posted May 31, 2006 Well for those of you who have torn into an EA82, you know those o-rings that go in between the cam case and and heads? One per side, located toward the top IIRC. I'm looking at replacing those while the engine is apart and was wondering if these are them?http://oem.thepartsbin.com/parts/thepartsbin/wizard.jsp?year=1989&make=SU&model=LOY-4WDT-001&category=All&part=Cam%20Housing%20O-Ring&dp=false Thanks! to answer your question..thats them,,you can use almost any o-ring that is with in 1 mm to the original....so dont be to fussy about paying $4.16 or there abouts...you can buy them for around 1 cent each.....go to a plumbing shop or simular/hardware store etc..you,ll come across some place that has a whole stack,your size...and are just itching to sell some.. ..cheers Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 31, 2006 Share Posted May 31, 2006 The correct o-ring (yes - that is the one) is not really an "o-ring" at all. It's a metal washer with rubber molded around it. While you can indeed use a regular o-ring, the metal is there to resist the "flattening" effect that a regular thickness rubber ring would have. Less rubber = less flattening as the seal ages. Personally I wouldn't use "just" an o-ring. Again - it's not that it won't work - it's that it won't work for the usual lifeime of the OEM part. GD Link to comment Share on other sites More sharing options...
idosubaru Posted May 31, 2006 Share Posted May 31, 2006 they are on the bottom, but that doesn't really matter. do not buy a generic o-ring for this part. like GD said this is not a normal o-ring at all. i have seen (and posted the pic even) someone re-use an old one with sealant. the sealant got sucked up into the oil passages and caused oil supply problems to that side valve train. the same could happen with a normal o-ring. the good news is that the partsbin o-ring is indeed the right part. thepartsbin is the only aftermarket supplier i've seen that carries this (one reason i'm impressed with them). Subaru sells them for $2.10 each i believe. alot for an o-ring. but it's not a normal o-ring and it's still less than $5 for the two you need, so no point in trying to be cheap about this one. i've bought tons of them from Subaru, i usually keep a few on hand. Link to comment Share on other sites More sharing options...
jacobs Posted May 31, 2006 Share Posted May 31, 2006 Rocket Seals doesn't sell "cheep" o-rings. Their primary market is the hydraulic market rebuilding hydraulic cylinders. This is a MUCH more severe application than in an automotive engine. I'm sure their o-rings are at least as good as oem Subaru or most likely a lot better. Link to comment Share on other sites More sharing options...
idosubaru Posted May 31, 2006 Share Posted May 31, 2006 Rocket Seals doesn't sell "cheep" o-rings. noone has used the word "cheap" or said anything about this place. we're making sure that people know the cam shaft o-rings in question here aren't really o-rings in the typical sense. they have metal in them, orings do not. there are alot of seals/o-rings on the cam carrier, best to make sure we're talking about the right ones. are you talking about the ones between the cam carrier and the head? were the ones you got metal? Link to comment Share on other sites More sharing options...
jacobs Posted May 31, 2006 Share Posted May 31, 2006 Yes I'm talking about the area between the cam carrier and the head. I just replaced my original non leaking o-rings with dimensionally identical o-rings when I replaced my timing belts. Maybe I'm missing something here but if there isn't any movement between the parts, and there isn't here, then any additional metal would actually be a detriment to sealing in my way of thinking. Link to comment Share on other sites More sharing options...
idosubaru Posted May 31, 2006 Share Posted May 31, 2006 the original OEM Subaru part is metal with a rubber o-ring compound exterior. when you replaced your timing belts you also pulled the entire cam carrier off, pulled the rocker arms and all? Link to comment Share on other sites More sharing options...
jacobs Posted May 31, 2006 Share Posted May 31, 2006 I think I may have opened mouth, inserted foot or maybe opened computer........ oh well, anyway, I was talking about the o-ring between the camshaft support and the case. Next time I'll think twice before responding. Sorry for the confusion. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 31, 2006 Share Posted May 31, 2006 Rocket Seals doesn't sell "cheep" o-rings. Their primary market is the hydraulic market rebuilding hydraulic cylinders. This is a MUCH more severe application than in an automotive engine. I'm sure their o-rings are at least as good as oem Subaru or most likely a lot better. Also - while hydraulics are a severe application, the cam case o-rings are subjected to more heat than a typical hydraulic system, and engine oil usually has trace amounts of fuel solvents dissolved in it as well. A regular o-ring will flatten out, harden, and possibly crack and get sucked into the oil passage - causeing all sorts of damage in the process. EA82 lifters already have a tendancy to tick loudly if you make a funny face at them - lets not make the problem worse with incorrect oil seals.... Lets see..... save ~$4.... or spend $5 and have the correct part.... your call. GD Link to comment Share on other sites More sharing options...
Caboobaroo Posted May 31, 2006 Author Share Posted May 31, 2006 and since I'm also running a slightly modded EA82T, not just "any o-ring" will work because its either replace a $5 part now or another engine. Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted May 31, 2006 Share Posted May 31, 2006 and since I'm also running a slightly modded EA82T, not just "any o-ring" will work because its either replace a $5 part now or another engine. Good point.Don't take a chance on something like that. Link to comment Share on other sites More sharing options...
Caboobaroo Posted June 1, 2006 Author Share Posted June 1, 2006 Good point.Don't take a chance on something like that. yeah I'm currently going through it with my engine I just pulled out. Decided not to buy a new oilpump and went with a reseal and look what happens..... Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 1, 2006 Share Posted June 1, 2006 yeah I'm currently going through it with my engine I just pulled out. Decided not to buy a new oilpump and went with a reseal and look what happens..... Now you feel just like I do about oil pumps huh? :-\ GD Link to comment Share on other sites More sharing options...
jeffast Posted June 1, 2006 Share Posted June 1, 2006 i for one am beggening to see the light Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted June 23, 2006 Share Posted June 23, 2006 Woh. I just found those OEM O-Rings for $1.61 a piece at RockAuto.. click here you just need to do a parts search for #A4002-56062. The thing is you have to buy 10, which makes it $16.10 plus shipping. Better than $4 something. I know this is an old thread, but I don't think it's . (HAH I've always wanted to use that!) -Justin. Link to comment Share on other sites More sharing options...
Turbone Posted June 23, 2006 Share Posted June 23, 2006 I just bought 2 from the Dealer for almost the same price. Internet price:D Link to comment Share on other sites More sharing options...
idosubaru Posted June 23, 2006 Share Posted June 23, 2006 http://www.thepartsbin.com has them for not much money either and you can buy just 2 if you like. but then shipping... dealer charges me $2.13 around here and they usually have them in stock. Link to comment Share on other sites More sharing options...
SuBrat84 Posted June 23, 2006 Share Posted June 23, 2006 RockAuto .. you're likely to get some "cheap" and/or "generic" Maybe you guys have had some success with them.. but IMO rockauto SUCKS. Woh. I just found those OEM O-Rings for $1.61 a piece at RockAuto.. click here you just need to do a parts search for #A4002-56062. The thing is you have to buy 10, which makes it $16.10 plus shipping. Better than $4 something. I know this is an old thread, but I don't think it's . (HAH I've always wanted to use that!) -Justin. Link to comment Share on other sites More sharing options...
idosubaru Posted June 23, 2006 Share Posted June 23, 2006 in this case it's an OEM part. Subaru OEM parts are outsourced to various companies. in some cases these parts are available through other (non OEM) sources. i can't stand the rockauto website. it's rediculously inefficient. look up the XT6 and it shows 4 cylinder parts all over the place...i don't know what the point is of drilling down if it's going to list 4 cylinder parts for a 6 cylinder vehicle. no other site does that...... okay i'm done. Link to comment Share on other sites More sharing options...
