I'm not sure if shutter is the right word to describe what I feel but it's the best I can come up with...
My problem: While stopped or at low speeds <5-10mph the steering wheel is hard to turn and shutters when i turn it. As soon as I'm moving decently it seems to go away. Fluid level is fine, car tracks okay, everything else seems to be fine.
I think it might be the ps pump as it happens at a rather constant frequency when it occurs.
If you guys agree, where is a good place to shop for a new one. Everywhere I look online I find them for over $240. Any used OEM replacement part retailers out there?
Any input would be greatly appreciated. Thanks all.
Best,
Eric
p/s pumps don't usually go bad on subies (or so I've heard). They are expensive. If this is your problem then your going to have to take the hit, or find a good one at a junkyard. Check your tension on the belt before anything.
Whats the car??
of course there's plenty of fluid!!
Best,
Eric
The car is a 1997 Subaru Outback 2.5L Limited (Legacy chasis)
Yeah there is plenty of fluid, that was the first thing I checked..
I was told sometimes the steering rack brackets come loose so I jacked up the car this morning to check and when steering the rack stays put as it should.
One thing however, a while ago I was having bad belt squeel, its been tightened and started doing it again, so I put belt dressing on it which made it stop. It hasn't done it in weeks/maybe over a month now. Could that have fried the pump?
Best,
Eric
