()__1337_CRAYOLA__()> Posted June 1, 2006 Share Posted June 1, 2006 I Have A Auto Gl Wagon I Want To Do A 4wd Convertion But Dont Want To Have to Put In A Different Pedel Set For A Manual. Did They Make Any Good 4wd Trannys In Auto Or Should I Just Sell My Car And Buy A 4wd Manual D/r Wagon... Link to comment Share on other sites More sharing options...
Caboobaroo Posted June 1, 2006 Share Posted June 1, 2006 doing the conversion to a manual is actually pretty simple. The hardest part about swapping pedal clusters is removing the old one and removing the steering column. Link to comment Share on other sites More sharing options...
()__1337_CRAYOLA__()> Posted June 1, 2006 Author Share Posted June 1, 2006 Yeah i don't really want to hasle with the pedels but did they make a good auto 4wd tranny? Or im gonna just buy a new one Theres a 4wd one down the street for 600 Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 1, 2006 Share Posted June 1, 2006 Much better to just buy another wagon. They are plentiful, and the FWD Auto makes a nice economical commuter. They serisously get like 35 MPG freeway. A conversion requires a LOT of parts - even more for an Auto conversion. Take it from me - I've done it. And I had a whole donor car to work with. GD Link to comment Share on other sites More sharing options...
idosubaru Posted June 1, 2006 Share Posted June 1, 2006 are you asking about the swap itself, auto transmissions or 4WD capability? swapping is a PITA like he just said. if you can, wait for a good deal on what you want then sell the other. if you have loads of spare time and want to do this, then tear it up. having a complete donor car would be key to making this easy on yourself. it's easy to pick one up with issues for not much $. the auto transmissions aren't too bad. keep the tires matching and buy a cheap spare trans just in case. i had to replace mine around 155,000. the used one i insatlled made it another 70,000 no problems and i'm installing it in my other XT6 hopefully someday. i'm a weirdo but i don't mind the AWD auto transmissions at all in terms of off road traction. install the Duty solenoid C switch and an LSD and you're golden. the switch is the key though, it's awesome. but i don't rock climb and plow through pits...unless i have too. more function than play for me and i never have problems getting where i need to go. Link to comment Share on other sites More sharing options...
