MischivousSlpwlkr Posted June 1, 2006 Share Posted June 1, 2006 Can anyone tell me how to find the timing marks on my '96 OBW 2.2l? I'm gonna go in there and check the timing/condition of the belt later today, and I'd rather not go in blind....Thanks! Link to comment Share on other sites More sharing options...
idosubaru Posted June 1, 2006 Share Posted June 1, 2006 the timing belt related marks are on the cam sprockets (youll see when you pull the covers) and the crank mark is on the flexplate (auto trans) or flywheel (manual trans) as viewed through the bellhousing access hole on top of the bellhousing underneath the intake hose where it meets the throttle body. you like run on sentences right? Link to comment Share on other sites More sharing options...
nipper Posted June 1, 2006 Share Posted June 1, 2006 the timing belt related marks are on the cam sprockets (youll see when you pull the covers) and the crank mark is on the flexplate (auto trans) or flywheel (manual trans) as viewed through the bellhousing access hole on top of the bellhousing underneath the intake hose where it meets the throttle body. you like run on sentences right? i got tired just reading that nipper Link to comment Share on other sites More sharing options...
Legacy777 Posted June 2, 2006 Share Posted June 2, 2006 The marks should be similar to the first gen 2.2's. here's pics from my t-belt job http://www.main.experiencetherave.com:8080/subaru/images/timingbelt/ Link to comment Share on other sites More sharing options...
