I looked at this really clean 94 SVX with leather and AWD.
The guy says head gasket but its not smokeing any antifreeze out the exhaust and it runs dam good and smooth.
only problem is oil consumption in the rad, its sucking oil in to the radiator and I wanted to know if these cars have oil coolers in the rad that could have broke.
So let me know what you think, thanks.
A trans cooler leak can certainly put ATF in the coolant, but it will also usually put coolant in the ATF, often seen as an emulsion (like mayonnaise) on the trans dipstick. If the ATF/dipstick look normal, it's more likely to be a head gasket problem. Checking for bubbles, HCs, CO2 at the radiator filler might be telling.
