skishop69 Posted June 7, 2006 Share Posted June 7, 2006 My Brat is Gen II EA81. When I change to the EA82 5 spd d/r, do I need to swap diffs as well. I don't know what my ratio is, have been told EA82's are 3.9. What's the skinny? Quote Link to comment Share on other sites More sharing options...
calebz Posted June 7, 2006 Share Posted June 7, 2006 Not all EA82s are 3.90 .. Only the 3.90 ones Check your diff. it came with a tag on it. 90% of the time I find them to still be in tact and legible Quote Link to comment Share on other sites More sharing options...
skishop69 Posted June 7, 2006 Author Share Posted June 7, 2006 So I need to check the tags on both the donor vehicle and mine to match or make sure I get 3.9. Thank you. Quote Link to comment Share on other sites More sharing options...
torxxx Posted June 7, 2006 Share Posted June 7, 2006 easy way to make sure with out getting under the car. if the donor car is a 5 speed dual range with selectable 2wd its going to be 3.9 Basically stay away from turbos and automatics and you'll be fine Quote Link to comment Share on other sites More sharing options...
Phizinza Posted June 7, 2006 Share Posted June 7, 2006 easy way to make sure with out getting under the car. if the donor car is a 5 speed dual range with selectable 2wd its going to be 3.9Dunno about the US, but it's totally random here. I have seen a 85 with 3.9, a 88 with 3.7, and 89 with a 3.7 first two were Touring wagons, other was a standard wagon. My bro has a 83 wagon with a replaced gearbox which is 3.9 and a wrecked 82 wagon with a 3.7... My 89 Brumby/Brat is 3.7.I also asked the ausubaru (waist of time, but what the hell) about it and the resaults were random too.. Only thing that was steady was LSD's being 3.7 (cos we didn't get the XT6 with the 3.9.) Best thing to do is swap the rear diff with the gearbox.. But you will know if theres something wrong while in 4WD on the pavement! Quote Link to comment Share on other sites More sharing options...
RONAN Posted June 8, 2006 Share Posted June 8, 2006 I know we`ve been through this before but I will mention again. My 87 Gl wgn had the EA82 spfi with a 5spd D/R and a 3:70LSD from the factory... Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 8, 2006 Share Posted June 8, 2006 I know we`ve been through this before but I will mention again. My 87 Gl wgn had the EA82 spfi with a 5spd D/R and a 3:70LSD from the factory... Yeah - it was an "order only" option that way tho - extremely rare. Oh - and you AUS and NZ guys do have a random assortment - like the Brumby being 3.7..... ALL 3.9 here. Best to check the tag on the diff, but here in the states you will find as stated above that most 5spd D/R's with 2WD (can test this by putting it in gear and watching the rear output while turning the input shaft) will be 3.9. The few exceptions are the 86/87 RX transmissions etc...... if it came from a turbo it's 3.7 GD Quote Link to comment Share on other sites More sharing options...
calebz Posted June 8, 2006 Share Posted June 8, 2006 The few exceptions are the 86/87 RX transmissions etc...... GD 85-86 Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 8, 2006 Share Posted June 8, 2006 85-86 Doh - yeah that's what I meant. GD Quote Link to comment Share on other sites More sharing options...
