homebrew subaru hybrid
suba
After seeing the recent crop of hybrids on the market I've really started thinking about the advantages, especially with gas prices. I would really like to be able to afford to drive, so hybrid might be an option, however there are two problems:
1. I like awd, i have to ski
2. I try to keep my car purchases under $1000
Obviously this doesn't work out, so has anyone retrofitted a subaru to be a hybrid? I'm sure it can be done, the question is how cheap and how well. Thoughts?
You'd go broke buying car batteries, and hybrid car bodies are designed to be lighter to make up for the excess weight of the batteries. I don't think it would give you a successful level of efficiency. Good thought though.
i heard that toyota and soob are gonna team up on some hybrid powertrains..i think it was in a road and track mag. my dad had..
From what I understand, Toyota is giving Subaru hybred technology in return for AWD technology.
Correct. And even with a lightened body, a hybrid is still a long term investment if you expect to see any noticeable returns.
And ... if you are a predominately highway, as opposed to stop & go city driver, you'll NEVR see any advantage.
actually if you make a true hybrid then you'll get 100-200mpg
the "hybrids" that are out now are more like dual-drivetrain (gas and electric) rather than hybrid
to make a true hybrid then you'd need the entire drivetrain to be electric with a gas generator on board
hope that helps, and it should be able to recoup your investment sooner, also most people buy hybrids to relieve their own dependance on oil rather than save money
there's one out here (justy sized car) thats electric. 80s subaru sherpa with a jet starter motor running at 72v - has a 200km run between charges and runs 110km at full speed. I have a spare shell and thought of a similar idea
I meant a littler simple version of a hybrid i guess. In town a regenerative braking system would improve efficiency, but the components and control system would be expensive and complicated to do. I was actually thinking of an electric hybrid system for highway crusing. A hybrid that has an electric motor and a gas generator works because once a car is at speed it takes a lot less power to keep it going. So what if on the highway the engine switched to powering a generator and an electric motor powered the car?
so the gas motor would only be for the generator? if so that's the most efficient way to do it
you plan on having four electric motors or two?
well, my thinking was that the gasoline engine would provide all power for acceleration by keeping a fairly stock drivetrain, while the electric motors would take over at cruise speeds. At cruise the engine would be disengaged from the wheels and act as a generator to power the electrics. as far as how the electric motors link into the system i'm not sure how to do that yet.
huh, I thought it was the opposite; electrics are used for torque from a stop.
personally I think that in the real world trying to adapt a gas/electric hybrid system to a $1000 car in order to save money on gas on a car that probably already gets 30mpg makes NO sense whatsoever.
plus, don't you want something you have faith in when its icy, 15 degrees, pitch black and youre up in the mountains?
I agree it would be cool to see if it could be done and all, but would be too experimental to take skiing. but prove me wrong!!! that would be awesome.
