Jaysz Posted June 8, 2006 Share Posted June 8, 2006 Ok I was coming home just a bit ago and the car seemed to be running rough , pulled into a bank to tap mac, turned the car off, went back about 1 minute later and the car wouldn't start. Finally started but ran very rough, drove home about 1/2 mile or so, pulled into the driveway and that was it. Car stalled out and now when I try to start it, it doesn't crank, it makes a noise like it normally would when you start it but no crank. I'm figuring my timing belt broke, it has 166k on it I was told the belt was replaced at 105k but apparently that was not true. How can I go check to see if that is actually the problem, could it be anything else? If that is it there is a guy from the SVX forum who will replace it for me what parts do I need, as he told me to source my own parts. Thanks in advance for any help anyone can give. Link to comment Share on other sites More sharing options...
Andyjo Posted June 8, 2006 Share Posted June 8, 2006 Check to see if you have any vaccum lines not connected, specifically the one that always gets bumped, under the airfilter thing. Link to comment Share on other sites More sharing options...
svxpert Posted August 20, 2006 Share Posted August 20, 2006 <<I try to start it, it doesn't crank, it makes a noise like it normally would when you start it but no crank.>> if your timing belt breaks on this car, the engine will still crank. it just won't start. i have a subaru only shop in south jersey. you can mail me at subarueast@yahoo.com Link to comment Share on other sites More sharing options...
tcspeer Posted August 21, 2006 Share Posted August 21, 2006 You can take one of the plactic covers off in the front and see if the belt is broke, but if it is broke the engine will turn over much faster when you crank on it then it will if it is not broke, so you should be able to tell without removing the cover. You might want to take the fuel line off at the filter and see if you are getting fuel. My fuel pump went out last week and it run kind of like what you are saying yours does. Ok I was coming home just a bit ago and the car seemed to be running rough, pulled into a bank to tap mac, turned the car off, went back about 1 minute later and the car wouldn't start. Finally started but ran very rough, drove home about 1/2 mile or so, pulled into the driveway and that was it. Car stalled out and now when I try to start it, it doesn't crank, it makes a noise like it normally would when you start it but no crank. I'm figuring my timing belt broke, it has 166k on it I was told the belt was replaced at 105k but apparently that was not true. How can I go check to see if that is actually the problem, could it be anything else? If that is it there is a guy from the SVX forum who will replace it for me what parts do I need, as he told me to source my own parts. Thanks in advance for any help anyone can give. Link to comment Share on other sites More sharing options...
