skishop69 Posted June 10, 2006 Share Posted June 10, 2006 Just to clarify... What years/models of the EA82 have the lower range 4lo for better ratio w/ bigger tires? Just want to be sure as I have an opppertunity to purchse a set up. Link to comment Share on other sites More sharing options...
kayakertom Posted June 10, 2006 Share Posted June 10, 2006 Generally, it was the manual gl models that came with dual range transmissions. I would not rely on either the year or model of the ea82 cars to tell what you may be getting - if its still running around after 15+ years, it's likely had driveline parts changed. Link to comment Share on other sites More sharing options...
mellow65 Posted June 10, 2006 Share Posted June 10, 2006 If I remember right around the time they changed the name from GL to Loyale they did away with the D/R and only went with the push button, that was 1990. And then all DLs were puch button. So 1985 to 1989 GLs would be what you are looking for. But even some of them were push button too. So it's best to just ask. I found asking if there is the button in the stick shift was the best question to ask over the phone, no one forgets the little red button. Hope that helps. Link to comment Share on other sites More sharing options...
calebz Posted June 10, 2006 Share Posted June 10, 2006 kayakertom said: Generally, it was the manual gl models that came with dual range transmissions. I would not rely on either the year or model of the ea82 cars to tell what you may be getting - if its still running around after 15+ years, it's likely had driveline parts changed. Not at all. It is not uncommon to see 200k + miles on the EA82 5 speeds. I have seen many of them outlast pretty much every other part on the car. Mine for example. It is 18 years old. The car it came from has ceased to exist(as a car anyway), but the tranny is still going strong. To the OP. I could be wrong about this, but the standard NA DR uses the same gearing throughout the EA82 model years. I know that on the EA81 4 speed DR, there is a slight difference between the early ones and the later ones, but again, I don't thinkn that applies to the EA82s Link to comment Share on other sites More sharing options...
