Camber adjustment?
Hey all,
Just a quick question for the suspension gurus out there. Is there a way to adjust out the camber on the front of my '88 4wd Gl wagon. It's got pretty bad possitive camber from adjusting the front struts ('85-'86) up to almost the max. Thanks in advance for any advice, Toby
It's been ten years since I did any strut work on my Subies... Can't remember if the strut clamps into or bolts to the knuckle. If it bolts on with two bolts then you take a die grinder to the bottom holes and oblong them horizontally. If it clamps into the knuckle the only option i could think of is to pray to the Subaru Gods that someone makes a camber kit. If you've got good fab skills, you could adapt a cam bolt set up to the lower control arm. I'm sure one of the guru's here knows a simple fix.
