ShawnW Posted June 11, 2006 Share Posted June 11, 2006 I traded off my turbo crossmember and steering rack and now need to put a manual rack and standard crossmember into the car. 1-Are there any racks that turn less or more lock to lock in these years or are they all the same? 2-Are the 2wd and 4wd crossmembers the same? 3-Tie rods the same? Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted June 11, 2006 Share Posted June 11, 2006 I believe they are all the same. If you need one, I can get one from a '83 DL 4wd wagon up here. Free of charge, just trying to get rid of the dang thing. Quote Link to comment Share on other sites More sharing options...
ShawnW Posted June 11, 2006 Author Share Posted June 11, 2006 2-yes according to parts manual Quote Link to comment Share on other sites More sharing options...
ShawnW Posted June 11, 2006 Author Share Posted June 11, 2006 I believe they are all the same. If you need one, I can get one from a '83 DL 4wd wagon up here. Free of charge, just trying to get rid of the dang thing. Oh that'd be awesome! Is it bolted to the crossmember still? Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted June 11, 2006 Share Posted June 11, 2006 its still all bolted in the car, steering column and all! Even has 4 wheels on it:D Quote Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted June 11, 2006 Share Posted June 11, 2006 Hey Shawn so what are your plans for the turbo traction wagon? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 11, 2006 Share Posted June 11, 2006 I have noticed that the power steering racks are easier to turn even without power.... ratio I'm not sure on. I have lost the belt (or more accurately the ability to run the belt ) on my wagon, and I've found that it still turns easier with 28's than my stock Brat does with 185's. I drove it unpowered for a couple months before repairing the idler pulley bearing. Works great still. Using the power rack and cross-member also means you *could* add power to it later if you decide that's something you want. Fitment should be the same with either type. Just cap off the power steering line ports on the rack and it should work fine without the power assist. Leave the lines on the bottom of the rack that allow fluid transfer from one side to the other, and keep the rack filled with ATF and it will be just fine without it's pump. If you can find one, and are into retrofitting, the preliminary measurements I made show the non-power EA82 rack to be the same length as the EA81 rack - the wider track of the EA82 is made up using different tie rods. I noticed once when I drove a non-power EA82 that it almost felt like it had power - it's was VERY easy to turn. I'm not sure what is different - perhaps a different/easier ratio or something. But I liked it I know that..... GD Quote Link to comment Share on other sites More sharing options...
ShawnW Posted June 11, 2006 Author Share Posted June 11, 2006 Hey Shawn so what are your plans for the turbo traction wagon? Im putting an EJ22 in it with the 88 RX Ft4wd transmission. Im keeping 3.70 gears for gas mileage and the lo range trans should be nice even if its not the super low. Quote Link to comment Share on other sites More sharing options...
ShawnW Posted June 11, 2006 Author Share Posted June 11, 2006 its still all bolted in the car, steering column and all! Even has 4 wheels on it:D PM me with details on how to get it and when I can come. Quote Link to comment Share on other sites More sharing options...
DerFahrer Posted June 11, 2006 Share Posted June 11, 2006 Shucks. I should know this for sure, but I think the XT has a quicker rack than other EA82's, if that helps. I know you're talking about an EA81, but they should interchange right? Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted June 11, 2006 Share Posted June 11, 2006 Just shot a PM your way Shawn Quote Link to comment Share on other sites More sharing options...
