PoorManzImpreza Posted October 29, 2003 Share Posted October 29, 2003 Damn why are subaru engine's so undercarbed? so guys weber on ea71 or acquire that ea71 dual carb intake that my muffler guy teased me with and slap two ea82 hitachi's on it? Link to comment Share on other sites More sharing options...
PoorManzImpreza Posted October 30, 2003 Author Share Posted October 30, 2003 no oppinions guys? Link to comment Share on other sites More sharing options...
bushbasher Posted October 31, 2003 Share Posted October 31, 2003 A stock ea71 isn't going to be overcarbbed with 2 ea82's on it. I'd go the weber route then you don't have to deal with crabby sube carbs, and you won't have to worry about keeping them in sync or anything. Link to comment Share on other sites More sharing options...
bbbs53 Posted October 31, 2003 Share Posted October 31, 2003 My '80 has a 32/36 DGEV. Simple install and simple to dial in. Makes it go as good as it is going to. I have noticed that they are a little fussy about vacum leaks. Outside of that, No Hitatchi's! Link to comment Share on other sites More sharing options...
JonOfScio Posted October 31, 2003 Share Posted October 31, 2003 you can't put EA82 hitachis onto an EA71 because of the bolt pattern... you'd need an adapter. EA81 and EA71 bolt patterns for the carbs are the same though... need a EA81 hitachi in good condition? Link to comment Share on other sites More sharing options...
Caboobaroo Posted October 31, 2003 Share Posted October 31, 2003 the only problem with the dual carb setup is "where are you gonna get the intake from?" Other than that it should work but IMO, you should weber it. Easier and a lot cheaper to do that a dual card setup Link to comment Share on other sites More sharing options...
JonOfScio Posted October 31, 2003 Share Posted October 31, 2003 whatever funkmeister, you are drooling over Andrew's dual EA71 manifold (with non-feedback carbs) Link to comment Share on other sites More sharing options...
Caboobaroo Posted October 31, 2003 Share Posted October 31, 2003 yeah yeah yeah, I know but still, where would anyone else be able to find a complete intake with carbs and all? I know moosens just bought a intake off of ebay for about 30 bucks I think but that was just the intake Link to comment Share on other sites More sharing options...
JonOfScio Posted October 31, 2003 Share Posted October 31, 2003 if someone wanted to really go all out, on an EA81, they could get the dual carb manifold, and put on two 38 DGEV carburetors. along with a beefy cam, with higher lift (torque cam preferred) new hydraluic lifters new evenly weighing pushrods (exact weight is preferred) new evenly weighed lightweight forged aluminum 10:1 CR pistons ($400) new/used 1600 pistons rods (handle more than the EA81s do) new hi-po valve springs, new valves... (replace all valve train basically) I'm sure if someone out there in this world did all of that with a good port and polish and sweet exhaust, they could have an evil carbureted monster. Don't forget a nice 4wd Centerforce clutch. (dual friction race clutch, lifetime warranty, kit is only about $250) Link to comment Share on other sites More sharing options...
PoorManzImpreza Posted October 31, 2003 Author Share Posted October 31, 2003 ok lemme qualify my car as my sig says is a an ea71 powered ea82 wagon...it doesn't have the same intake as a 70s early 80s ea71s it has a bigger inside and outside diameter and the carb is an ea82 bolt pattern non feedback w electric choke, so in complexity it is about equiv to the weber or perhaps slightly more. Now given that our ea82 carbs are different compared to the USA as we NEVER got the feedback carb I'll need to personally verify the SRX dual carb manifold bolt pattern to see what is what...bleh.. As 2 the ea81 carb...I like my electric choke..does the ea81 have it? also I'd be getting the hitachis free and u can't get webers here unless you import it yourself..$$ I honestly don't mind fabricating adapter plates as I'll have 2 do the same with the carb linkages and fuel lines and water supply hose. The SRX manifold actually had the original carbs on it but they were in pretty bad shape... but damn this engine is being held back...I remember reading somewhere that the SRX had a 274 duration cam w higher lift as well...I could with time probably drop an ea82 engine in the car but I'd need an ea82 flywheel as my ea71 wheel won't bolt up 2 the ea82 crank and I've NEVER even seen a manual ea82 car here..as I'm def not going slush box route my only option untill I get that ea82 flywheel or redrill and balance my ea71 wheel is to get the most out of my ea71.. long post LOL sorry guys Link to comment Share on other sites More sharing options...
Rattle wagon Posted June 18, 2005 Share Posted June 18, 2005 I Have Two Dual Carb Setups But No Air Cleaners, If You Find One Hang Onto It For Me I'm About Two Steps From Putting It On My 78' Brat With The Factory Carbs, And I Believe You Need The Specific Carbs Due To The Jetting, Side Of Carbs Say Left & Right Respectively. If You Want To Weberize The Dually You Need 1 Dgv & 1 DFV With Manual Chokes Because The Ports Are To Close Together Auto Chokes Clash. Link to comment Share on other sites More sharing options...
PoorManzImpreza Posted June 19, 2005 Author Share Posted June 19, 2005 OMG talk about digging up old topics lol I went the ea82 carbed route..redrilled my 1600 flywheel to 1800 bolt pattern..and about 5 months after that found an ea82 4wd flywheel AND an ea82 fwd flywheel...time heals all wounds I'm now preparing to move on to turbo ea82 and EFI.. still have that dual hitachi SRX manifold tho'... Link to comment Share on other sites More sharing options...
