pamike Posted June 11, 2006 Share Posted June 11, 2006 how is the passenger side mirror held on, on a 96 legacy. it's loose and wanted to tighten it. Link to comment Share on other sites More sharing options...
brus brother Posted June 11, 2006 Share Posted June 11, 2006 If there is a triangular shaped piece at the inside of the door from the mirror, gently pry it loose and you'll find a few nuts behind that should tighten it up. The triangular piece has three small plastic wings that can be broken if you just tear into it. Link to comment Share on other sites More sharing options...
pamike Posted June 12, 2006 Author Share Posted June 12, 2006 it has a little speaker behind the mirror. how would this come off. Link to comment Share on other sites More sharing options...
brus brother Posted June 12, 2006 Share Posted June 12, 2006 Use a small screwdriver to gently pry off the speaker grill and you should then see the actual speaker being held on by the same nuts that hold the mirror to the outside. Link to comment Share on other sites More sharing options...
