suby do Posted June 12, 2006 Share Posted June 12, 2006 Has any body got a wiring diagram for a '97-8 liberty/legacy? Trying to find a good take off point for an extra wire for accessory such as a little fridge in the back of the wagon have run a wire to the back now just need somewhere that gives ACC.only using say the CIG. outlet which allows 20A, but finding the wire is proving difficult. Link to comment Share on other sites More sharing options...
Cougar Posted June 12, 2006 Share Posted June 12, 2006 Has any body got a wiring diagram for a '97-8 liberty/legacy?Trying to find a good take off point for an extra wire for accessory such as a little fridge in the back of the wagon have run a wire to the back now just need somewhere that gives ACC.only using say the CIG. outlet which allows 20A, but finding the wire is proving difficult. If I was doing this I would use a fuse tap in the fuse panel to provide the connection. Looking at my reference it shows SBF-1 is a 30A fuse that supplies power to the sun roof. It also supplies power to fuse #11 in the fuse panel which is a 20A fuse to supply power for the door locks. By putting a tap on the hot side of fuse #11 it will be taking power from SBF-1. You can purchase fuse taps that replace the original fuse and have a slot to put the fuse back in along with another fuse to power your addition. By using a tap you don't alter the wiring. Link to comment Share on other sites More sharing options...
suby do Posted June 12, 2006 Author Share Posted June 12, 2006 Fuse tap sounds like the way to go. I haven't heard of them but will try to get hold of one. Thanks Link to comment Share on other sites More sharing options...
Cougar Posted June 12, 2006 Share Posted June 12, 2006 Using a tap makes it so easy to add a extra fused circuit. A good auto parts store or marine parts outlet should have them. Link to comment Share on other sites More sharing options...
Lawsonmh15 Posted June 15, 2006 Share Posted June 15, 2006 Has any body got a wiring diagram for a '97-8 liberty/legacy?Trying to find a good take off point for an extra wire for accessory such as a little fridge in the back of the wagon have run a wire to the back now just need somewhere that gives ACC.only using say the CIG. outlet which allows 20A, but finding the wire is proving difficult. Any and ALL wiring diagrams out of Alldata. PM for a PDF. Link to comment Share on other sites More sharing options...
