waimaks Posted June 13, 2006 Share Posted June 13, 2006 Ok, I've got a friend with an 89 Legacy. Its got an Carbed EJ18, and the ever fun Dual range AWD. But anyway, he had been telling me it had been running rough and nearly dieing at cold. I sort of thought it might have been something to do with the auto choke or coolant temp sensor (do these even have one of those?) He reakons its been getting worse lately, running rough all the time and backfiring down hills etc. A mechanic took a quick look at it for him and he now says that his carb is just fawked pretty much.... Anyway, a search has pretty much told me that carbed ej18s aren't common I think? Any info on these things would be cool. At the moment hes thinking of just replacing it with a carb from the wreckers. Thanks in Advance! Link to comment Share on other sites More sharing options...
LPGsuperchargedBrumby Posted June 13, 2006 Share Posted June 13, 2006 as far as i know ej18 carbs only came in 89 legacys so he might have some fun trying to find a replacement carb. btw the dizzy off a ej18 carb model bolts straight onto a ej22 OBD1 allowing you to run a carbed ej22 without a ECU Link to comment Share on other sites More sharing options...
waimaks Posted June 14, 2006 Author Share Posted June 14, 2006 Ok, thats interesting. Will help a bit with the search for parts. Thanks:). I like Subaru legos:) Link to comment Share on other sites More sharing options...
Setright Posted June 14, 2006 Share Posted June 14, 2006 Are you sure it's a fuel problem? Try adjusting the mixture. We used to detach the vacuum hose from the carb when we set the idle mixture. It's much easier with the hose off. Could be worth dismantling and clean the carb, before searching for a "new" one. Link to comment Share on other sites More sharing options...
