I need a quick clarification.
The Tail housing and rear output shaft on the EA81 version are longer then the ones on a EA82, similar to how a D/R 4 speed is longer then a D/R 5 speed. I have had a couple of dozen 3ATs apart and those parts can be swapped fairly easly; you will need to make sure that you keep transfer gear set matched up.
