murphsubaru Posted June 14, 2006 Share Posted June 14, 2006 How do you ajust the emergency brake cable on a 99 Forester? I need to remove the slack. When the handle is pulled all the way up I don't get much braking. Quote Link to comment Share on other sites More sharing options...
ferret Posted June 14, 2006 Share Posted June 14, 2006 If it's an L model with Rear drum brakes, I would ensure the self adjuster are working correctly. If it is an S model with rear disks, they use a seperate small brake shoe in the center for the emergency brake. If all the above are working properly then the attached .pdf file shows how to adjust the lever/cable. Quote Link to comment Share on other sites More sharing options...
murphsubaru Posted June 15, 2006 Author Share Posted June 15, 2006 Ferret, could you please repost the pdf file. When I open it all I get is jibberish. Thanks Quote Link to comment Share on other sites More sharing options...
ferret Posted June 15, 2006 Share Posted June 15, 2006 Your browser isn't setup correctly. Right click and save the file, then open it from your PC. Quote Link to comment Share on other sites More sharing options...
Shep2112 Posted January 3, 2007 Share Posted January 3, 2007 Has this attachment been removed? I don't see any kind of link for it anywhere. Thanks! -Eric Quote Link to comment Share on other sites More sharing options...
