weber carb q's
i am in spokane....if you need help with it i could look at if you want.....i have been through plenty of trouble with them before.have rebuilt three webers as of late and rebuilt a whole ************ load of hitachis as well.:grin:let me know...
i have already done that and it did nothing.
Did you tighten the vertical screws that attach the "throttle body" to the main casting?
They are inacessible unless the carb is removed.I`ve found these to be a problem on the carter/webers.
yes i have taken it off and tighned those, when it is first started weather it is warm or cold out it hesitates real bad and will also hesitate a little when warm. also gas milage is real badi can maybe get away with 215 miles to a full tank. yeah its horrible
