seth3030 Posted June 14, 2006 Share Posted June 14, 2006 My weber is running real crappy and i was wondering where i could get a new/ rebuilt one on the net for a reasonable price? or how would i put a hitachi on there? Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted June 14, 2006 Share Posted June 14, 2006 You are still better off with that weber than a hitachi.You can get rebuild kits off of ebay or the redline weber site.Good luck. Link to comment Share on other sites More sharing options...
TomRhere Posted June 14, 2006 Share Posted June 14, 2006 http://www.carburetion.com/Weber/weber.htm Should find what you need there. Link to comment Share on other sites More sharing options...
monstaru Posted June 14, 2006 Share Posted June 14, 2006 i am in spokane....if you need help with it i could look at if you want.....i have been through plenty of trouble with them before.have rebuilt three webers as of late and rebuilt a whole ************ load of hitachis as well.:grin:let me know... Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted June 15, 2006 Share Posted June 15, 2006 Lets clarify wether your talking about the Weber 32/36 DGEV?? Or the stock 1bbl Carter/Weber? -Brian Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 15, 2006 Share Posted June 15, 2006 Sounds like he's talking about the carter/weber - tighten the bolts on the base and it will probably be fine. GD Link to comment Share on other sites More sharing options...
seth3030 Posted June 15, 2006 Author Share Posted June 15, 2006 i have already done that and it did nothing. Link to comment Share on other sites More sharing options...
naru Posted June 15, 2006 Share Posted June 15, 2006 i have already done that and it did nothing. Did you tighten the vertical screws that attach the "throttle body" to the main casting? They are inacessible unless the carb is removed.I`ve found these to be a problem on the carter/webers. Link to comment Share on other sites More sharing options...
scrap487 Posted June 15, 2006 Share Posted June 15, 2006 how about some details about the symptoms? Link to comment Share on other sites More sharing options...
seth3030 Posted June 15, 2006 Author Share Posted June 15, 2006 yes i have taken it off and tighned those, when it is first started weather it is warm or cold out it hesitates real bad and will also hesitate a little when warm. also gas milage is real badi can maybe get away with 215 miles to a full tank. yeah its horrible Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted June 15, 2006 Share Posted June 15, 2006 You still havent answered my question, but i assume your talking about the single barrel carter/weber. -Brian Link to comment Share on other sites More sharing options...
seth3030 Posted June 15, 2006 Author Share Posted June 15, 2006 oh yeah it is sorry Link to comment Share on other sites More sharing options...
