Hello.
Somebody on alt.autos.subaru suggested I post this message here:
I'm wondering if anyone else has noticed the following behaviour out of
their engines.
I have a 2003 OBS with 110k kms. Lately I have noticed that the engine
RPM seems to drop much faster between shifts than other times. It
makes it difficult to shift smoothly since my normal wait time results
in the RPMs being way too low. I had noticed this behaviour on hot
days last summer, but I have been noticing it more recently. It seems
to happen randomly, Sometimes only for one shift, sometimes for a whole
drive.
Any thoughts?
Chicobker
Hello.
their engines.
drive.
Any thoughts?
Chicobker
Is this with an Automatic? If it is, and is actually happening in the process of shifting, odd as it sounds, it may be the brake bands in the tranny. What I am referring to is a dip WHILE shifting. If so, do an ATF flush (I like the Royal Purple) and if it is still apparent and REALLY bothering you, adjust the brake bands.
Nope. 5spd.
I'm not convinced of the a/c suggestion, although it is the right time of the year! Several times I've noticed this happening only between 2nd and 3rd gear. I find this strange.
I find that most times when I push in the clutch, the RPMs go up ever so slightly, hang for a moment, then start to drop down. I got used to holding the clutch in for that brief moment and then letting it out and the shifting was reasonable. (I never found it to be easy to shift smoothly, but I took that as a "feature" of the Subaru!) I've been doing this for 3.5years now.
What I'm experiencing now is an immediate drop in RPMs as soon as I push the clutch in. It plummets towards zero and by the time I realize what's going on and let the clutch out it's too late. Car lurches forward and attempts to throw me out through the windshield. Maybe it's trying to trade in its driver?!
At first I figured that my brain had somehow forgotten how to drive and I was doing different things with the accelerator pedal, but I've been conscious about it and it is still happening.
Anyway, I'm taking the car into the dealer on Monday to deal with occaisional sputtering during the first minute of driving on a cold wet morning, so I'm hoping they find something and that all will be better.
Chicobiker
Could be your idle air control. This controls the engine rpms at idle or when the engine is unloaded. The technical term for it is that the engine rpm is flairing up when you depress the clutch.
nipper
nipper
I second that.
Here is a link to a PDF I uploaded that explains the procedure without having to disassemble much. http://home.comcast.net/%7Elawsonmh15/Idle_Air_Control_Solenoid_Valve_Service.pdf Should do the trick.
Here is a link to my thread http://www.ultimatesubaru.org/forum/showthread.php?t=46484&highlight=IACV
I'd also recommend you purchase a can of BG 44k and run that through on a HALF a tank. I know they say full, but better concentration = better results. :burnout:
  • 2 weeks later...
Well, the car has been running great for a week now. The service guy greased the electrical connections between the coil and the spark plug wires. Car runs like it used to. RPMs behave like they used to.
Maybe it was just a bad electrical connection? Or maybe it will come back to annoy me at a future time.
Hesitation problem is also gone, so I suspect they were related.
Chicobiker
