1988 Justy Problem. Help Please!
I've been super busy lately but guess what? There is NO ignition module in my 1988 Justy's distributor! Subaru must have gone to a different system in 1989. They did change a buch of stuff when they upgraded the 1989 model as the 1987-1988 models are exactly the same. So I'm out of luck there. I called several dealers and they said there is no dist. ignition module in the 1988 model and the 1988 shop manual doesn't show one either.
One nice tech at one dealer took the time and said to check the wires coming out of the dist. that connect to the main wiring harness. He said he has repaired a couple with the same problem and that connection was loose or corroded and that cured it. I don't have time now but will check that soon and I hope that's the case.
  • 1 year later...
