nicky nighteyes Posted June 17, 2006 Share Posted June 17, 2006 My engine is hanging on the cherry picker and can't go back in until I find one. I need the one for the EA81 clutch. I have tried everywhere and the only place who has one in stock is NAPA, and you gotta buy the whole clutch kit:mad: I don't believe you can just install the pressure plate hand tight and tighten the bolts through the starter hole due to the smaller clutch size. before I separated teh engine I tried and coulden't fit a socket in there, I might be wrong though. So if anyone local has one I would be much obliged if I could borrow it for ten minutes. thanks Link to comment Share on other sites More sharing options...
fastenova Posted June 17, 2006 Share Posted June 17, 2006 Got one. I'll be up there tomorrow evening most likely. Let me know if you need it. Aaron. Link to comment Share on other sites More sharing options...
nicky nighteyes Posted June 17, 2006 Author Share Posted June 17, 2006 sweet. thanks, i let you know if I haven't found one yet fastenova said: Got one. I'll be up there tomorrow evening most likely. Let me know if you need it. Aaron. Link to comment Share on other sites More sharing options...
Caboobaroo Posted June 17, 2006 Share Posted June 17, 2006 Nicky, just loosen up the pressure plate a bit, enough to move the clutch disc around with a bit of force, and use a screwdriver and your eyeballs to line it up. I've done this on numerous Subarus before I got my EA81 and EA82 alignment tools Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 17, 2006 Share Posted June 17, 2006 Yeah - I sugested that too.... can't hurt to try if it's on a picker right? Only if you can write off the time investement if you can't get it to work I suppose..... The splines are slightly beveled near the end, and I think it should work - the springs in the disc should afford it a small amount of play doing it this way.... GD Link to comment Share on other sites More sharing options...
nicky nighteyes Posted June 17, 2006 Author Share Posted June 17, 2006 maybe I will give it a shot just eyeballing. Link to comment Share on other sites More sharing options...
()__1337_CRAYOLA__()> Posted June 17, 2006 Share Posted June 17, 2006 Go To Napa Buy the Cluch Kit, Use The Alignment Tool, Take It Back And Say It Was The Wrong One But You Found The Right one At Schucks or Something lol Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted June 17, 2006 Share Posted June 17, 2006 I have one. I may be able to swing by and drop it off if I have time. The wife is about to go on vacation so I may be super busy. I will try to get back online in the morning to check on this thread if time permits. Link to comment Share on other sites More sharing options...
nicky nighteyes Posted June 17, 2006 Author Share Posted June 17, 2006 if you get time to swing by that would be rad, I think I have it lined up pretty close, but I would like to make double sure, no sense pulling the engine twice. call me @ the number in my first post, I will be home most of the day. thanks Flow! Link to comment Share on other sites More sharing options...
nicky nighteyes Posted June 17, 2006 Author Share Posted June 17, 2006 got one, turns out the baxter I didn't call had one. a million thanks to all who offered suggestions/help. you guys are a stand up bunch. Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted June 18, 2006 Share Posted June 18, 2006 just got back home... sorry looks like I took too long. Glad you found one Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 18, 2006 Share Posted June 18, 2006 You really should give me a + board rating for that . I told ya Baxter's had a whole shelf of em..... Man I love me sometimes :-p GD 1 Link to comment Share on other sites More sharing options...
Phizinza Posted June 18, 2006 Share Posted June 18, 2006 Probably been said already, but... My brother is my clutch aligning tool. (no, his not a tool. but he does a good job at being one.) He uses a screw driver, and his eye. His done it 3 times for my EA81 and it always went straight on no probs. I have tried it a few times, but only got it right after the third try. So anyhow, doing it by eye is completely possible. It does help if you have a engine hoist and engine leveler for it too. Link to comment Share on other sites More sharing options...
nicky nighteyes Posted June 18, 2006 Author Share Posted June 18, 2006 GeneralDisorder said: You really should give me a + board rating for that . I told ya Baxter's had a whole shelf of em..... Man I love me sometimes :-p GD actually they had only one, hanging on a hook, and they were the only baxter that had em. The two others I called didn't. but screw it, +1 anyway Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 18, 2006 Share Posted June 18, 2006 Neato! I meant a whole shelf of "alignment tools" - not specifically subaru. I remembered seeing them at the Baxter on 99 out my way. I just noticed it was cool they carried the tools without buying the whole kit.... so I figured they could probably get one in if they didn't stock our specific size. I should still make the "high quality" alignment tool tho eh? Would be a neat conversation peice. hehe. GD Link to comment Share on other sites More sharing options...
nicky nighteyes Posted June 19, 2006 Author Share Posted June 19, 2006 you should... of course you will probably never use it, only the small 200mm clutches that you can't get through the starter hole. maybe you could wear it on a chain, blinging. for everyone saying "wtf is he talking about?" GD had the idea of taking an old pilot shaft off a blown tranny, boom, instant "heavy duty' metal clutch alingment tool. Link to comment Share on other sites More sharing options...
Caboobaroo Posted June 19, 2006 Share Posted June 19, 2006 nicky nighteyes said: you should...of course you will probably never use it, only the small 200mm clutches that you can't get through the starter hole. maybe you could wear it on a chain, blinging. for everyone saying "wtf is he talking about?" GD had the idea of taking an old pilot shaft off a blown tranny, boom, instant "heavy duty' metal clutch alingment tool. I have one of those from a gen 1 tranny. I think its at my parent's house in Oregon though... Link to comment Share on other sites More sharing options...
