EGR lite on 86 gl won't go out
the wagon is an 86 carbed gl, new engine, minimal smog junk,no oxygen sensor,doesn't want to idle below 900rpm.&the dash egr lite will not go off. have tried 3 diff carbs, 2 different egr valves,1 vacuum solenoid,sprayed ether at all hose joints trying to find vacuum leak to no avail.can't figure out where the egr lite is getting it's signal from.have disconnected battery several times trying to get ecm to reset,no go, am getting a tad frustrated, any ideas will be tried THANKS DAN
let me guess......you just rolled over 180k miles a couple days ago.....and as previously stated, its milegae controlled. maybe you should have come to us sooner...that way you didnt have to pull and replace all those carbs and EGR stuff, kinda makes you mad that its just 2 little wires huh?
~Josh~
~Josh~
right u are i dug out an old chilton manual & there it was, big as life so i swapped wires & guess what not a damn thing happened, car has 107 kms. & it's been sitting 20 yrs.just found out about u.s.m.b. yesterday or i would've been here yrs. ago.we are up in the sticks of no. b.c. info kinda trickles in up here.any further ideas on how to turn that damn lite off?? how about i leave it disconnected??
