DOJ mix-n-match
Sorry, can't say for sure. But I would think so.
I heard that the EA DOJ's will fit in Early Liberty Cups.
So I would think the 23 to 25 spline cups would be the same... *I would think*
Fat load of help I am, huh...?
There is a combination that will do the job - there was a member that did the EJ/AWD 5 spd conversion to a Brat (Brumby) quite some time ago. He stated that he used the DOJ cups from a early 90's Legacy Turbo (92/93 vintage). What I don't know is if he was using 2WD or 4WD EA81 front axles. I'm assuming 4WD as that is what the Brat came with originally.... but you never know. Most likely the 4WD EA81 axle will slide into the legacy turbo cup. A real write up would be nice, but thus far no one has come forward.
when i was looking for driveshafts to fit an RX AWD box with 25 spline output shafts i found you can get
inner DOJ with 25 spline to gearbox and 25 spline to axle
inner DOJ with 25 spline to gearbox and 23 spline to axle
axle with 25 spline inner and 25 spline outer
axle with 25 spline inner and 23 spline outer
outer CV with 25 spline to axle
outer CV with 23 spline to axle
so basically any combination you can think of is out there, but actually finding out which configuration comes off witch car.. good luck!
i think a lot of it depends on the manufacturer of the driveshaft
happy hunting
Bluesteel
Check this post: http://www.ultimatesubaru.org/forum/showthread.php?t=57559
NKN I80723
Thats a Subaru 25/23 spline DOJ.
http://www.nknjoints.com/ is the company.
Johnnyboy in Christchurch, NZ picked those up at his local CV shop.
I had no luck finding them in the US. and Shops want about $150 a piece to make the axles (which is a fair price, actually).
What I'm gonna do is use some EA81 FWD auto axles and swap on some early Legacy inner joints I have. I've verified that the splines match up, with a junk set I had. Hopefully the good pair I just got from Jerry also work with the Legacy joints and cups. I'll let everyone know how it works out when I get around to trying it.
well i got a 25 spline doj/axle assembly and a ea82 23 spline doj/axle assembly and pulled them apart to see A,if the 23 spline doj had a 23 spline axle shaft in it and B, if the cups would swap.
both the 23 & 25 spline doj's have 25 spline axles in them :mad: so i can't use them on my brumby rx 'box conversion:banghead:. but the cups swapped
so rather than trying to :horse: i think i'll shell out the $600 that they want for the off the shelf 25/23 spline cv's so i won't be getting them for another month or so.
on a side note the ea82 dojs i've got are hugely bigger in dia than the ones that are on my brumby like about 12-15mm
when i did my ej swap i used the inner cups off a 91 legacy and my original shafts, balls, and never even took the shafts out of the car.
Yeah EA82 DOJs swap with legacy DOJs, but neither will swap onto an EA81 4WD axle shaft.
But they will swap onto an EA81 FWD axle.
That's how I'm going to put an 5MT in my hatchback.
do ea81 FWD's have a 25 spline axle shaft?
I'm not quite sure what you're asking.
EA81 FWD's have 23 Spline DOJs, just like EA81 4WDs.
BUT, EA81 FWD axles are compatible with EA82/Legacy DOJs so you can make a 25 spline axle out of an EA81 FWD axle using an EA82 or Legacy DOJ.
sooo... the actual axles shaft splines on the ea81 FWD shaft its self are 25 spline?
Great news then mate!
Let me know how you get on with the cheaper ones... i might pick up another set for my next project!
Can you PM me where you got them from?
On a side note, i paid $450 for my set up.. which i thought was crazy at the time, but $600 is worse.. perhaps prices went up?
There are like 21 or 22 splines on the shaft, something like that, but anyway it's the same number as are on EA82 and Legacy shafts. Meaning you can throw a stock EA82 or Legacy DOJ on a stock EA81 FWD axle. I just did a pair earlier tonight.
But anyway, it looks like you're all set now, but I figured I would throw the info out there for the record.
both 23 and 25 spline ea82 doj's i pulled apart the other day where fitted to 25 spline axle shafts
I had to convert 25 spline axles to 23 today at work. I was amazed at how fast one can do them. takes about 2 minutes to cut the old band off, pull the retainer ring, swap cups slide boot back, reband it.
Its official.....im a RETARD!!!! :banana:
i was in such a rush to to post the cheque to get my DOJ's that i forgot to.........(drum roll) put the address of the outfit i was sending it to :headbang:.
fortunatly all my enverlopes have my return address stamped on the back
:clap:
guess im just brain:dead:
so my DOJ's won't be here till next week sometime:mad:
ea82 TURBO 3spd AT axles are 23 spline with the fat diameter cup that swaps directly with 25 spline.
doe's anyone know if the doj innerspline/cage and balls for a 23 spline front axle will fit in a 25 spline cup?
what im trying to do is fit a FT4wd RX 'box into a brumby, now i can get off the shelf DOJ's that will do this....but i kinda need all my arms and legs:lol:
