moosefarmer Posted June 18, 2006 Share Posted June 18, 2006 has anyone taken apart the idle circuit solenoid & removed the needle valve, how will the carb work? i'm thinking i have a problem that is in the solenoid, & was just wondering if removing that needle valve would create any other probs? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 18, 2006 Share Posted June 18, 2006 It may diesel when you shut it off. You can test that thing - just apply 12v to it while it's off the carb and see if the needle gets sucked in. FWIW, I've never seen one fail. GD Link to comment Share on other sites More sharing options...
moosefarmer Posted June 19, 2006 Author Share Posted June 19, 2006 GeneralDisorder said: It may diesel when you shut it off. You can test that thing - just apply 12v to it while it's off the carb and see if the needle gets sucked in. FWIW, I've never seen one fail. GD THANKS just was wondering what it might do. still can't get the engine to idle below 1000 rpm. must be a vacuum leak i can't find. thanks again DAN Link to comment Share on other sites More sharing options...
