Dangerdave Posted June 18, 2006 Share Posted June 18, 2006 Hey, I have a 2001 legacy gt engine that I'm preparing to install in my 93 Impreza. I've noticed a bit of oil in the spark plug tube. I understand that there is a boot that can fall down? Can anyone tell me what this part is called? I'm hoping to order it and replace it before the weekend. Thanks, Dave Link to comment Share on other sites More sharing options...
sea#3 Posted June 18, 2006 Share Posted June 18, 2006 It is a seal that goes on the sparkplug tube ,you should replace all 4 . You should also replace the valve cover gaskets and the grommets under the valve cover bolts , since you have to pull the valve covers to do the job SEA#3 Link to comment Share on other sites More sharing options...
