hxcjunglist Posted June 19, 2006 Share Posted June 19, 2006 OK. I couldn't find too much information on google about this, so I thought I might try something on a forum. I started my 2003 Subaru Legacy a couple weeks ago and the engine was making quite a racket. I turned the engine off imediately. I had a few people take a look at the engine with me and we noticed the timing belt was loose on the right hand side. The noise can be described as pot and pans falling down a set of stairs. Anyways, one of my friends said my engine was screwed because the valves and pistons may have crashed into each other because the timing may have jumped. Another person said it may not be that and I should just change the timing belt and see how it runs after that. I know I could probably have someone check the pistons out with a borescope. Anyways, my question is... How easy is it for an engine of this type to ruin the pistons and valves? I know the engine could be an Interference engine type, but I'm not sure. Basically I just want to know if I'm screwed or not before I replace the timing belt. Link to comment Share on other sites More sharing options...
DerFahrer Posted June 19, 2006 Share Posted June 19, 2006 Well, first off, is your Legacy a 1993 or a 2003? Either way, a Legacy is a New-Gen car, so this belongs in the New-Gen forum. If it's a 2003 and your timing belt slipped, then you could very well have engine damage. If it's a 1993, it will not have engine damage, even if the timing belt broke completely. Link to comment Share on other sites More sharing options...
