Sarge Posted June 20, 2006 Share Posted June 20, 2006 Anyone know if there is a frame out there that an EA81 hatch will fit on comfortably? I've been wanting to do this but I have no clue where to start. Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted June 20, 2006 Share Posted June 20, 2006 Suzuki Samarai -Brian Link to comment Share on other sites More sharing options...
monstaru Posted June 20, 2006 Share Posted June 20, 2006 if you use a zuke,you need like 7 or 9 inches..........if you use a nissan,you cut some out,if you use a jeep ,you only need 3 inches or so.....i been wondering too. Link to comment Share on other sites More sharing options...
bratsrus1 Posted June 20, 2006 Share Posted June 20, 2006 Hey sarge This is Jerry, yes i am doing a suzuki sammy frame on my hatch now. I had to add 13 inches in it and the sammy frame fits inside of the subaru frame. I am hoping to have it all done for the show this year, it's going to wild. Thanks Jerry Link to comment Share on other sites More sharing options...
Sarge Posted June 20, 2006 Author Share Posted June 20, 2006 How do ya get the steering to match up? I would assume the only thing Roo you are using is the body and possibly interior... I think I'm gonna go with a Jeep frame, Anyone have any clue which model Jeep is the closest? Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted June 20, 2006 Share Posted June 20, 2006 Hey sarge This is Jerry, yes i am doing a suzuki sammy frame on my hatch now. I had to add 13 inches in it and the sammy frame fits inside of the subaru frame. I am hoping to have it all done for the show this year, it's going to wild. Thanks Jerry That sounds awesome! Link to comment Share on other sites More sharing options...
75subie Posted June 20, 2006 Share Posted June 20, 2006 i bet a 70s cj jeep frame would be close, the wranglers would brobly be too big. how about a geo tracker frame? i hear those 1.6's they have in those, with a 5speed d/r is pretty bulletproof. plus it would be good on gas. those trackers have a solid rear axle and manual front lock in hubs with independent axles. just a thought.... Link to comment Share on other sites More sharing options...
Sarge Posted June 20, 2006 Author Share Posted June 20, 2006 I know I am revealing my ignorance here... but what is d/r ? I really want to use a Jeep frame cuz of the extensive off road market for them. My goal is pretty much build a monster Jeep with a subaru body and some of my own custom add-ons. Link to comment Share on other sites More sharing options...
75subie Posted June 20, 2006 Share Posted June 20, 2006 d/r, = dual range 4wd, or high-low 4wd Link to comment Share on other sites More sharing options...
970subaru Posted June 20, 2006 Share Posted June 20, 2006 what about toyota frame? they are real strong if not rusty and have one of the better drivetrains. seen complete, solid trucks non running in the 300-400 range. might be easiest to just relocate the rear axle to suit the body? a wagon would be pretty sweet on a toyota frame. is it easy to keep the body low or do you have to like cut out the trans tunnel? Link to comment Share on other sites More sharing options...
monstaru Posted June 20, 2006 Share Posted June 20, 2006 the jeep cj-7 is 93.5" the yj and tj are both 93.4" these are wheelbase numbers. now on a brat it is only a 3.3 inch difference. on a hatch it would be around 93.3 good luck.....and oh yeah........searching is aloud:grin: Link to comment Share on other sites More sharing options...
Sarge Posted June 21, 2006 Author Share Posted June 21, 2006 I searched this topic and couldn't turn anything up or I wouldn't have asked. So with the wheel bases you are sayin that a YJ and TJ are pretty darn close to a hatch? I plan on body dropping the hatch on the frame and loading up the suspension. I don't know about the tranny tunnel. Link to comment Share on other sites More sharing options...
bratsrus1 Posted June 21, 2006 Share Posted June 21, 2006 Hey Sarge This is Jerry, the clostest i have found to match up with the subaru is a sammy frame. It fits inside of the subaru unibody and just add 13 inches to the middle of the frame and it fits. The jeep frame is close on wheel base but it is to wide. Come to the show and you will see my hatchbrat. I am useing sammy frame with rear end and front end and transfer case and sammy steering. Then i am useing the subaru engine with the 5 speed DR tranny. The after market has a lot of off road sammy stuff. Come to the show and see it. Thanks Jerry Link to comment Share on other sites More sharing options...
Turbone Posted June 21, 2006 Share Posted June 21, 2006 Jerry, I seriously doubt he is going to come all the way from Nashville for the show in Hood River, OR. Link to comment Share on other sites More sharing options...
Sarge Posted June 21, 2006 Author Share Posted June 21, 2006 Yeah, I'd like to go to the show, but it probably won't be this year. I am in school at Nashville Auto-Diesel College and I will be here until October. When you lengthen the Sammy frame, what drive shaft do you use? won't that make the sammy shaft too short? Any idea how much too wide the jeep frame is? Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted June 21, 2006 Share Posted June 21, 2006 There are these shops that can extend or shorten your drive shafts. A job like this will require ALOT of custom work, so you will have alot more to worry about than just driveshafts. -Brian Link to comment Share on other sites More sharing options...
Sarge Posted June 21, 2006 Author Share Posted June 21, 2006 There are these shops that can extend or shorten your drive shafts. A job like this will require ALOT of custom work, so you will have alot more to worry about than just driveshafts. -Brian The plan was to chop everything off the Roo from the firewall forward. mount the Roo on the frame. Tube frame the front end and hang sheetmetal when all is done. My main concerns were driveshaft, steering, pedals, tranny tunnel. what else do you have to add to my list of worries? Link to comment Share on other sites More sharing options...
monstaru Posted June 21, 2006 Share Posted June 21, 2006 the jeep frame is 66.7 inches,the hatch is 63.8 inches.jerry may think the frame is to wide because of where the frame would match up....but i think it would work.i want the extra width anyway.the driveshaft is a cakewalk.....your concerns right now need to be centering that body,making sure that a stuffed suspension is not going to mash up your rear 1/4 panels.cause were talkin mad flex for such a light body,even on stock springs. Yeah, I'd like to go to the show, but it probably won't be this year. I am in school at Nashville Auto-Diesel College and I will be here until October. When you lengthen the Sammy frame, what drive shaft do you use? won't that make the sammy shaft too short? Any idea how much too wide the jeep frame is? Link to comment Share on other sites More sharing options...
bratsrus1 Posted June 21, 2006 Share Posted June 21, 2006 Hey Guys This is Jerry, the sammy frame fits inside of the subaru unibody i didn't cut anything off of the subaru. When i am done with this set up if i want to i can go back stock with the subaru running gear. The pedales are all stock the steering i am useing the sammy. The only mod i will have to the body is a hole for the transfer box shifter and brackets welded to the unibody frame to hold the body to the frame. The rear drive line will be stock sammy ans the front i will have to lengthen and the center drive line i will have to lengthen. Hey sarge jump on the gray dog and join us at the show. Thanks Jerry Link to comment Share on other sites More sharing options...
Sarge Posted June 21, 2006 Author Share Posted June 21, 2006 I wish I could, man that would be awesome. But as of now, I have perfect attendance... that may seem cheap, but that is what employers look at. anyway, I don't mind the choppin' and as long as the jeep frame ain't wider than the actual car.... I'll make the neccessary sacrifices to do it, Since I was 13 I've always wanted a Subaru 4.0L with like 36"s. And about the suspension, I have that under control. It's a secret recipe one of my buddies uses and I don't want to let it out until I know if it works on the Jeep-a-Roo. Link to comment Share on other sites More sharing options...
Sarge Posted June 23, 2006 Author Share Posted June 23, 2006 So, does anyone know if the jeep frame is wider than the actual car or if it just won't fit as snug as the Sammy frame? Link to comment Share on other sites More sharing options...
monstaru Posted June 23, 2006 Share Posted June 23, 2006 i am still trying to find one i can measure in person without the owner coming unglued from me getting up under their car..... maybe jerry can give you the actual frame width of a sammy......... Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted June 23, 2006 Share Posted June 23, 2006 i am still trying to find one i can measure in person without the owner coming unglued from me getting up under their car..... maybe jerry can give you the actual frame width of a sammy......... i have a bare frame I dont need Link to comment Share on other sites More sharing options...
