NewDriverOlderRide Posted June 20, 2006 Share Posted June 20, 2006 I searched and looked in the USRM BTW. When I was new to Subaru Under the hood i connected the Green connectors, and the white connectors(thinking they were supposed to be) now I pulled the codes, 12 and 34. I fixed the problems, and now I dont know how to clear the codes. Which connectors are supposed to be connected?(the green and white) or are they left un-connected? Link to comment Share on other sites More sharing options...
hooziewhatsit Posted June 20, 2006 Share Posted June 20, 2006 connect the greens, then go for a drive. If the CEL starts blinking, it means the computer didn't find any codes. Just disconnect the greens when convenient. If the CEL comes on solid, pull over and check the blinking code.... Link to comment Share on other sites More sharing options...
NewDriverOlderRide Posted June 20, 2006 Author Share Posted June 20, 2006 hooziewhatsit said: connect the greens, then go for a drive. If the CEL starts blinking, it means the computer didn't find any codes. Just disconnect the greens when convenient. If the CEL comes on solid, pull over and check the blinking code.... THANKS! you can delete this now. Link to comment Share on other sites More sharing options...
