rti calculator..FIXED...
monstaru
My 2002 Forester got the following scores on a homemade actual 20 degree ramp, with the tires at 36psi:
100% Stock Forester = 397
100% Stock, but Anti Sway Bar end links Disco'd = 458
Yes, it can make a slight difference between front and rear, but it just comes down weight distribution.
I was able to get 548 with "Summer".
I did get a 585 a while back but not last night.
I'll have to mess with it a bit and see just how far I can push it
(with out rolling in my driveway)
Took some picks, I'll have to post them in a bit...
Glenn,
82 SubaruHummer--Summer with a 548
84 GL Mad Max--Untested
01 Forester--Has trouble going over tall bumps.
ok, the other day i got 385 on a 20 degree ramp.(doh edit the degrees)
today i did a 25 degree ramp and was only 318. regular tire pressure.will have to get more batteries for the camera(*********************)you know who you are!
sorry,her are some pics....pics
i am also going to put my other rear shocks on this week and should gain a bit more as it will allow more travel obviously in the rear and keep that rear tire on the ground.
***Link to ramp test pic***
http://www.ultimatesubaru.org/photos/showphoto.php?photo=11586&cat=500&ppuser=584
We don't have much suspension travel:-\
I think my shortened wheel base (80") is the reason for my score,
I also think the coil over shocks are hurting me.
I'm going to try unbolting the additional coil shocks and lower the PSI in the tires and see what the numbers are?:rolleyes:
Glenn,
