oil under the engine
EA81's don't have cam seals. EA82's do.
What vehicle do you have? Body type and stuff - 89 could be either engine.
As for leaks, about the only place an EA series engine won't leak is between the block halves. If you have the capability, the best way to deal with oil leaks is to remove the engine and reseal everything. It's neither difficult nor expensive in the case of the EA81, and the EA82 isn't far behind really.
