supergn6 Posted June 25, 2006 Share Posted June 25, 2006 Hello everyone I am new to the world of subaru I have a 1993 impreza with the 1.8 and i need to know what i can bolt on throw at this thing to get more power?? 131,000 miles runs good just slow really slow with the air on!! Link to comment Share on other sites More sharing options...
nipper Posted June 25, 2006 Share Posted June 25, 2006 nothing, unless you want to throw a turbo on it. You didnt say if its a manual or automatic. SUbarus have no hidden HP or torque anywhere, as they are free flowing engines as they are. nipper Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted June 25, 2006 Share Posted June 25, 2006 Hello everyone I am new to the world of subaru I have a 1993 impreza with the 1.8 and i need to know what i can bolt on throw at this thing to get more power?? 131,000 miles runs good just slow really slow with the air on!! take out weight. Less mass=greater acceleration. dead weight(tools, spare, seats if you never use them), rotating mass (lighter flywheel, crank pulley, and lighter rims for less rotating AND unsprung mass) Your car CAN be competitive at autocross with some suspension bits but will never be a 1/4 - 1/8 miler. swap in a 2.0 turbo from a wreck Carl Link to comment Share on other sites More sharing options...
supergn6 Posted June 25, 2006 Author Share Posted June 25, 2006 its an automatic,the 2.0 turbo that you mentioned what car does it come from and how much horsepower does it have over my 111,1.8 what does stock rims weight so i can compare them to after market wheels its a fwd not all wheel drive and how long will this motor last with care it has 131,000 miles Link to comment Share on other sites More sharing options...
nipper Posted June 25, 2006 Share Posted June 25, 2006 its an automatic,the 2.0 turbo that you mentioned what car does it come from and how much horsepower does it have over my 111,1.8 what does stock rims weight so i can compare them to after market wheels its a fwd not all wheel drive and how long will this motor last with care it has 131,000 miles the engine (motors are electrical devices, sorry pet peeeve) wil last as long as its maintained and not overheated. We have lots of soobies here crossing over into thw 200,000 mile range, and some over 300,000 miles. 1.8L is 110hp/110 ftlbs of torque (not bad by the numbers) 2,2 is 135/140 2.5 is 165/162 (1997 year of my car)) 2.2L turbo is 160/181, i cant find numbers for a 2L turbo. If its an automatic no matter what you do your going to lose alot through that pre 95 gearbox. nipper Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted June 25, 2006 Share Posted June 25, 2006 its an automatic,the 2.0 turbo that you mentioned what car does it come from and how much horsepower does it have over my 111,1.8 what does stock rims weight so i can compare them to after market wheels its a fwd not all wheel drive and how long will this motor last with care it has 131,000 miles Someone here has maybe done that swap using a JDM motor or a motor from a wrecked older STi. But there will be a lot of info on it over at www.nasioc.com . Dunno if you can do it into an auto. I dunno what your rims weigh, I saved 3.5 pounds per corner and got wider, nicer looking wheels on my car('06 WRX). You would likely double your HP. some good rim/tire info at http://www.tirerack.com too. Carl Link to comment Share on other sites More sharing options...
supergn6 Posted June 26, 2006 Author Share Posted June 26, 2006 thanks nipper and carl you guys are ok!! Link to comment Share on other sites More sharing options...
