seth3030 Posted June 25, 2006 Share Posted June 25, 2006 i need some new front struts and was wondering if / what strut should i look at(example just the oem ones ) or is there something that would be better? Quote Link to comment Share on other sites More sharing options...
baccaruda Posted June 25, 2006 Share Posted June 25, 2006 KYB GR2s are nice, and not too pricey. You can find them on ebay, usually for 2WD cars but those sit lower. Quote Link to comment Share on other sites More sharing options...
seth3030 Posted June 25, 2006 Author Share Posted June 25, 2006 thanks man. Quote Link to comment Share on other sites More sharing options...
Davalos Posted June 25, 2006 Share Posted June 25, 2006 What are your driving habit like? I ended up with some beefier (supposedly) ones in the back of mine, since I carry a lot of weight often, but the ride isn't that great. There are some that carry you smoothe as glass, and some that keep you low to the ground & smack you with every bump ... Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 25, 2006 Share Posted June 25, 2006 The GR2's are nice - but they do not make an exact replacement for the 4WD struts - ie they are not adjustable, and will ride lower than the stock ones. Monroe makes an exact replacement that includes the height adjusters and everything. It is also possible to replace just the strut cartridge from what I understand - cheaper, and retains the stock package with height adjustment. Little more work tho. GD Quote Link to comment Share on other sites More sharing options...
