'95 Legacy wagon check engine light
Guest sbiddle
I had a constant check engine light when the fuel level went really low, and I was able to clear it by disconnecting the battery for 20 minutes. Is this a common problem with this years legacy?
Also, can I read codes using the black and/or green connectors? or do I need to get the computer scanned with OBD2?
Thanks,
SBiddle
95 Legacy Wagon
Guest Legacy777
If you get a code, don't just clear it right away without checking it. When you get it again, go to autozone or another bigger name autoparts store, they should be able to check the code for you.
  • 1 year later...
