has there been an consensus made about what ampreage fuse you're supposed to use for the FWD fuse box?
it appears that my dutyC doesnt have power (i think a wire came apart from my Andyjo awd-4wd conversion switch) and i dont really want to drive around like that until i can take it to the garage on wednesday.
Correct - any old fuse will do. The Duty Solenoid C draws about 1.9 amps when it is engaged. There is a bit of a current inrush (i.e. transient spike) which is probably why Subaru recommends a 15 amp fuse, although I've used a 10 without blowing it for quite a while (nearly 2 years!!) in the past.
