att: SHAWN W
Im not aware of that article.....I think theres a lot of wheel info from the old USRM left to be transfered to the new USRM though.
I don't think there is a definite way to put flat spoke jackmans on an 80's Subaru. They work fine on the rear drum brakes but the fronts dont like them.
I saw a set of chrome jackmans fitted to a EA82 at Johns shop.
there is no more data left to be converted to the USRM. Everything that wasnt converted was either to vauge to understand correctly, or the HTML was so jacked up i couldnt convert it to the new interface. I made sure all the valuable information had made it over, and im always adding new info.
If you have a set of jackmans, maybe you can fit them to your car and find out why they wont fit. Then make the necessary modifications to make them fit. Then I can add that to the USRM.
-Brian
