daeron Posted June 30, 2006 Share Posted June 30, 2006 hey all.. 87 gl-10 A/t.. i just checked under the hood and the rear bolt that secures the A/C compressor and alternator bracket to the block is MISSING! i am going in to work a busy friday night in hot south florida, if ANYONE can reply to this thread with specific bolt and thread dimensions i can stop at a store and buy a new one to put in, but i need this ASAP so my roomate can check the thread and update me..... thanks in advance for the answer, im sure someone here can tell me... peace, shawn Link to comment Share on other sites More sharing options...
idosubaru Posted June 30, 2006 Share Posted June 30, 2006 RANDOM GUESS: 10mm x 1.25 pitch pitch i am sure of...diameter not so much. often you can pull one that's not quite as necessary from somewhere else and put it where you need it. is it causing any issues? Link to comment Share on other sites More sharing options...
calebz Posted June 30, 2006 Share Posted June 30, 2006 I think Gary is right about the size. I used to have the same problem with the same bolt (I even have the same car) I found out that the bolt that was in there is just slightly too long and was bottoming out before it was truly tight. A small lock washer added to the equation and its been there for three years.. only coming out when I tell it to Link to comment Share on other sites More sharing options...
Numbchux Posted June 30, 2006 Share Posted June 30, 2006 I think gary's right also....I do know that it's a 14mm head. and only 1.5-2" long. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 30, 2006 Share Posted June 30, 2006 Should be as they say - 14mm head, and yes it needs a flat washer and a lock washer on it to prevent it from coming out. GD Link to comment Share on other sites More sharing options...
