second skin rep Posted July 5, 2006 Share Posted July 5, 2006 Man... Just got a new 2276 Air cooled VW engine built. less than 4 hours of play time and she blew a rod. Not going back to that mechanic again. So now I want somthing powerful, light and reliable. Looks like I need to get an EA81 That is what I gather from all of my searching on the net. Most rail owners that are using subaru engines use the ea81. anyone have any comments or suggestions before I get going with this project? Any help is appreciated. ANT Link to comment Share on other sites More sharing options...
bushbasher Posted July 5, 2006 Share Posted July 5, 2006 how much power does a 2276 vw motor make, cause one could hardly call an ea81 powerful. IMO you should go straight for an ej18 or ej22. The only difference would that you would have to do electrical work for the fuel injection on the ejxx motor. The ea81 motor would be carbbed which is simple to hook up, and the motors are really cheap, but you are only looking at <100hp With the ejxx motor you will get >100hp, fuel injection, and near the same reliability. Link to comment Share on other sites More sharing options...
ShawnW Posted July 6, 2006 Share Posted July 6, 2006 I agree with bushbasher. 135HP with most Ej22's (2.2L engine) (stay below 1996 so you dont have an interference engine). Link to comment Share on other sites More sharing options...
jeffast Posted July 6, 2006 Share Posted July 6, 2006 from the reading i have done plus all the stuff i have read on this board plus other rumors i'd hav to definatly vote the ea81 or the ej22 ej22 you get way more power but with the ea81 there is no electronics nothing to break no timing belts etc. however you get around double the bang for your buck with an ej22 and those things are hard to kill Link to comment Share on other sites More sharing options...
Sweet82 Posted July 6, 2006 Share Posted July 6, 2006 Welcome to the board. I think you'll enjoy either motor. The only problems I see is the addition of a radiator to your Rail. Good Luck, Glenn 82 SubaruHummer 84 GL Mad Max 01 Forester Link to comment Share on other sites More sharing options...
Nug Posted August 18, 2006 Share Posted August 18, 2006 I've got a EJ22 in my '74 beetle. I recommend it highly. Link to comment Share on other sites More sharing options...
grinder_74 Posted September 17, 2006 Share Posted September 17, 2006 Nug said: I've got a EJ22 in my '74 beetle. I recommend it highly. That's an interesting idea! Where did you put all of the radiator, etc. pix? Link to comment Share on other sites More sharing options...
Nug Posted September 21, 2006 Share Posted September 21, 2006 What an awful picture. You get the idea. Link to comment Share on other sites More sharing options...
ben--ny Posted September 22, 2006 Share Posted September 22, 2006 ej2.2 wieghts in at 300lbs ready to run at 130hp ea81 80hp ready to run weight 175lbs 2.2 = 50hp more = 125lbs more in weight if it was me i'd skip 2.2 and go right to 2.5 weight in a 315lbs for the 15lbs in weight diff you get 35 more hps. if weighty matters ea81 if it don't 2.5 Link to comment Share on other sites More sharing options...
Nug Posted September 25, 2006 Share Posted September 25, 2006 I don't think they weigh that much. I can pick it up myself. Also, many older 2.5's have headgasket problems. There are several years of engines you will want to avoid. I bought my 2.2 for $125. It has ~150K on it, and I'm constantly hitting the rev limiter and dumping the clutch, and that engine loves being abused. I like the 2.2. Link to comment Share on other sites More sharing options...
beataru Posted September 27, 2006 Share Posted September 27, 2006 Id go wit a 2.5 and just put a lightend flywheel on it... itl sound good and... if its pushing a rail.. it'l go like smash! (lots and lots of people use ej's for sandrails! tough, reliable, and they soobies sound so nice!) Link to comment Share on other sites More sharing options...
