seanski06 Posted July 6, 2006 Share Posted July 6, 2006 its just a crappy little round piece, not much beef on it at all....am i going to be regretting it later on that i didnt drain my tranny oil again and replace it.....whats the symptons that can occur? when i replaced the drain plug i wraped some teflon tape around the threads so i dont think it'll leak.. (tho i could be wrong) and whats the normal amount of build-up to form at the magnet of the plug i have a 96 impreza 2.2 5-speed 197,700miles....and when i seen how much metal shavings were on the end of the plug (1/2 inch thick at least) it made my heart drop to my stomach.....this is the first change since i've had the car and i also changed the rear diff. oil and once again my heart sunk when i realized there was hardly any oil in it and the stuff that did come out....was a thick grey color....now that i changed it....its not as nasty of a noise now when going in reverse..it almost sounds like the normal whine that these cars have instead of the grinding dropping weights noise. Link to comment Share on other sites More sharing options...
Kilroy Posted July 6, 2006 Share Posted July 6, 2006 Take the car out for a little drive and get the engine warm and then park it on a clean spot. Check it in the morning for any oily spots on the ground beneath the plug. I don't think you will have any troubles, you put teflon tape on it to seal it. I'm wondering what happens to that tape once the threads are inside the tranny though. Will it break down in the hot fluid and come off the threads? Link to comment Share on other sites More sharing options...
seanski06 Posted July 6, 2006 Author Share Posted July 6, 2006 i was a little worried about using the teflon tape too...but now im somewhat glad i did....wasnt planning on forgetting the junky washer......i used teflon tape on the rear diff bolts too....probably shouldnt have but F-it i had to use the impact gun to get the damn things out next time i shouldnt have to Link to comment Share on other sites More sharing options...
ericem Posted July 6, 2006 Share Posted July 6, 2006 Ya same thing happened to me when my rear diff fluid and tranny fluid was changed, threatning what builds up in there. Link to comment Share on other sites More sharing options...
seanski06 Posted July 6, 2006 Author Share Posted July 6, 2006 ericem said: Ya same thing happened to me when my rear diff fluid and tranny fluid was changed, threatning what builds up in there. yours what all crapped up on the magnet? and ur diff fluid was a dark milky grey....i was thinking the worst when i seen that....kickin my self in the a** for not changing it earlier...i always knew something was up with the rear diff....b/c of the harsh noise from reverse...and no it wasnt just the normal grind b/c of the straight cut gear Link to comment Share on other sites More sharing options...
idosubaru Posted July 6, 2006 Share Posted July 6, 2006 i've seen about that much material on the magnets before as well. no problems came about on those vehicles, i bet you're fine. distribute all that fine grit across the many gears, plates and goodies inside the transmission and i bet it doesn't add up to much...like 0.01 mm of surface wear throughout the trans. best to have that crush washer in place, but probably won't leak without it. Link to comment Share on other sites More sharing options...
2X2KOB Posted July 6, 2006 Share Posted July 6, 2006 Don't worry about it, the guys that work in those 30 minute oil change places throw those washers away by the hatful and never have a problem. Link to comment Share on other sites More sharing options...
robm Posted July 6, 2006 Share Posted July 6, 2006 Don't worry about it, the guys that work in those 30 minute oil change places throw those washers away by the hatful and never have a problem No, their customers do! Link to comment Share on other sites More sharing options...
