ea82T heads vs. ea82 heads
i recently got a 87 turbowagon w/ 5 spd that had a cracked head. I have it in a shop getting pressure tested right now but i was wondering if the head off of an 89 GL n/a spfi would fit. I have an extra sube in my backyard and would like to swap parts in.
from the motor? the coil, the distributor (if your soob is spfi or mpfi non-turbo)
the little 100 dollar vacuum piece(forget what its called)
the vapor canister, starter, cam boxes and covers, oil pan, poi pump, water pump, timing belts, pulleys and covers.
pretty much anything that isnt the head or intake
